C63 AMG (W204) 2008 - 2015
CEL again
Old 06-27-2011, 04:55 PM
TEXC63's Avatar
2009 C63, 2500HD, OlllO Rubicon
CEL again
Got the dreaded CEL yesterday! I dropped the car off this morning at MB. Ended up being the intake manifold gasket was leaking. Has anyone else had the same issue?
Old 06-27-2011, 06:01 PM
CELLryuu's Avatar
C63 AMG Coupe P31
had the exhaust manifold leak but never heard of the intake leaking
Old 06-27-2011, 07:00 PM
_AMG_'s Avatar
C63
My buddy had the same problem (member: FaresUAE) its an easy fix.
I currently have the Evosport phenolic intake manifold heat spacers and are very happy with them.
Old 06-27-2011, 07:28 PM
Mikegpr03's Avatar
C63
Happened to me it's a common issue it seems. They replaced my gasket and installed an updated bolts. No issues since.
Old 06-27-2011, 08:52 PM
exdes's Avatar
2015 C300 4matic
same here.
Old 06-27-2011, 10:40 PM
BerBer63's Avatar
2009 C63
Any TSB on this and what code did you get?
Old 06-28-2011, 09:35 AM
TEXC63's Avatar
Codes where P0171 and P2187. I had it in two three weeks ago for a purge valve. CEL came back on two weeks later. They also had to tap two holes and replace the studs bolts. Not what you want to see on your invoice. Kind of makes me nervous...
Old 06-28-2011, 10:32 AM
exdes's Avatar
2015 C300 4matic
I had P0171. Replaced K&N filter, CEL came back right away, Replaced Purge valve then CEL came back on after a week..
Dealer invoice says they did smoke test, replace intake manifold gasket and bolts.
no more CEL.
Old 06-28-2011, 11:30 AM
TEXC63's Avatar
Sounds just like what has happend to me. How many miles have you run sense then? I've had K&N for years with no CEL.
Old 06-28-2011, 02:16 PM
exdes's Avatar
2015 C300 4matic
i think i put 2-3K miles since. K&Ns will be going back in when I have time since they were never the problem.
Quick Reply: CEL again
