C63 AMG (W204) 2008 - 2015
Goodbye RE11's. Hello PSS's
Old 07-07-2011, 08:34 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
5 hard track days and 7,000 Klm I think the RE11's are shot. They were a GREAT combo street and track tire. They will be hard to beat.
Enter 4 new Michelin PSS's 255.35.19F 275.30.19R
Attached Thumbnails Goodbye RE11's. Hello PSS's-photo.jpg   Goodbye RE11's. Hello PSS's-2photo-copy.jpg
Old 07-07-2011, 09:01 PM
HIRO63's Avatar
c63
Im thinking of changing my tire soon and thinking what size I should put on.
So putting on 255 front and 275 rear was no problem? No rubbing?
I have same wheel on the picture of yours and lowered with KW Clubsports.
What is the best size you think?
Old 07-07-2011, 09:45 PM
I don't have any issue with my stock p30 setup. I did push the Camber to -2 degrees so that did help a little. It may be close with the ClubSports. Whats the drop from stock??
Old 07-07-2011, 09:50 PM
_AMG_'s Avatar
C63
Ive been looking at the RE-11's or PSS as my next tire setup also, Please let us know how the grip and treadlife is on the Michelins.
Old 07-07-2011, 10:13 PM
aznkuja328's Avatar
12 M156 C204
me too.
regarding tread life, i am sure pss will last longer, but how about sidewall stiffness, cornering control, and dry traction?
are the 255s in the fronts good? it makes the steering feels more stable right?
i am deciding among re11, ad08, and pss...
Old 07-07-2011, 10:20 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Those RE11s look pretty good based on what you put them through. Good luck with the SSs.
Old 07-07-2011, 10:21 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
You Think they might be shot? Must have been some interesting final laps.
Old 07-07-2011, 10:24 PM
So far so good. Only about 200Klm on them today. The 255's feel more planted and turn in is quick and predictable. (street)
Wear should be better considering the 300 Treadwear rating vs 180 on the RE11's. Sidewalls are plenty stiff in the 19" variety.
Next track day isn't until Aug 3rd. will update after that...
Old 07-07-2011, 10:33 PM
LOL.. I've had the PSS's in my garage for a month now so I was anxious to make the change (Kid in Candy Store syndrome) Originally expected to get 1st week of August but ran an extra track day on Sunday and it was REALLY hot!! Took a fair amount of life off the RE11's. Almost swapped them out on Monday but figured they were good for 1 last event. (Yesterday)
The last tank of the day (140 Kilometers) was on the edge a good amount of the time. Really pushed it to the limit. Good times.
Here is a link to a Vid PC V (C55) shot of a few of our last laps. He cooked his fronts in the process. He very did well keeping up!! It was a great day had by all.
http://www.youtube.com/watch?v=WtP6a8Z5HmU
I have some in car video as well but need to find the time to edit and post. Maybe on the weekend... Have to figure out FCPX
Old 07-07-2011, 11:13 PM
I was very impressed with the Re11's. Expectations are high for the PSS's Some say the track much like the PSCups. Time will tell
Old 07-07-2011, 11:18 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
You'll like the Super Sports. Can't yet speak to their longevity though.
Old 07-08-2011, 12:13 AM
enochroot's Avatar
2016 G550
This is the same setup I want to run, same 19" AMG wheels but keep debating if I should run Michelin PSS 255/265 or 255/275.
Sounds like 255/275 is going to fit perfectly.
I'm a tire geek, if you can take a quick cell phone pic of the rear it would be greatly appreciated.
Old 07-08-2011, 03:12 AM
_AMG_'s Avatar
C63
Originally Posted by aznkuja328
me too.
They are supposed to be better then the PS2's in terms of grip and tread life which is a great thing.
255's are pretty wide for the front, especially Michelins because they run wide to begin with. Only other 255 tire ive seen mounted in the front for a C63 was the Toyo T1R tire which run pretty narrow.
Wider tires should definitely improve grip and cornering.
My Hankooks are almost done so I gotta shop around. Only thing Im worried about is rubbing since im lowered on springs, 275's would be cutting it pretty close.
Old 07-08-2011, 07:31 AM
hhughes1's Avatar
Where did you source the ME20's and did you use them for track days only?
Old 07-08-2011, 04:35 PM
_AMG_'s Avatar
C63
North 44, did you have any rubbing issues with the 275 RE-11's?
Old 07-08-2011, 09:32 PM
Let me see what I can do. Its dark here now..
Old 07-08-2011, 09:37 PM
Sourced directly from Endless. (Check PM) The ME20's for the C63 are special order and take 4-6 weeks to get out of Japan. Use them 24 /7
Old 07-08-2011, 10:03 PM
Not sure if this angle is what your after. Let me know.
Attached Thumbnails Goodbye RE11's. Hello PSS's-tire-1.jpg   Goodbye RE11's. Hello PSS's-tire-2.jpg
Old 07-09-2011, 04:13 AM
_AMG_'s Avatar
C63
Any rubbing with the 275 RE-11's?
Old 07-09-2011, 06:01 AM
Sorry I missed your question. Getting old.....
No issues with rubbing on the 275 RE11
PSS's are close but clearing all around
Old 07-09-2011, 10:12 AM
enochroot's Avatar
2016 G550
Thanks. I was hoping to see a pic from the side - facing the tire.
Want to see how the sidewall height looks.
It's not a big deal, I can live without it.
Old 07-09-2011, 10:24 AM
alrasheed1991's Avatar
2011 C63AMG P31
North44 does 255 on front fits well with out any rubbing do I need to do any or it is fit fine with 19" ?
Abdullah
Old 07-09-2011, 11:01 AM
Here you go>>> 36Lbs stone cold
Old 07-09-2011, 11:02 AM
Abdullah
Close but no rubbing anywhere. Good to go>>>
Old 07-09-2011, 11:05 AM
jspAMG's Avatar
C63, C300, 911TT x 3, 911 C2 x 2, 911SC, SL65, SL500, 280SL Plus some trucks
Just a note. The treadlife numbers for tires is not a standard measurement. You cannot compare one manufacturer to another on the treadlife number. They don't correlate. You can generally count on them within the same manufacturer but even that isn't always true, sometimes it only holds in a tire sub-type within that one manufacturers tire inventory.
So, theoretically, a 200 rated tire might last longer than a 300 rated tire from another company.
Jim
Quick Reply: Goodbye RE11's. Hello PSS's
