C63 AMG (W204) 2008 - 2015
help needed removing charcol filter in E63
Old 07-18-2011, 05:17 PM
gstatus929's Avatar
2014 E63 S-AMG
Hey guys,
I have a 2010 w212 amg E63. No one in my thread seems to respond.
I want to replace my air filters with either K and N or BMC filters. Please advise on the improvements from doing so.
Most importantly can anyone give me directions on the charcol filter delete. I cant figure out what to do. Any instructions with photos would be greatly appreciated.
Old 07-18-2011, 08:58 PM
box986's Avatar
W211 E63
loosen the screws around the airbox top cover and the clamps around the rubber hose, you will be able to see the charcoal filter under the top cover.
Attached Thumbnails help needed removing charcol filter in E63-amg-german-boxes.jpg
Old 07-19-2011, 10:27 AM
gstatus929's Avatar
2014 E63 S-AMG
so the charcoal filter will be on the top of the cover, and i just prob it out.
Any step by step diy's around.
Old 07-19-2011, 11:34 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
It is very easy to do, don't sweat it. Just get in and do it.
Old 07-19-2011, 01:20 PM
gstatus929's Avatar
2014 E63 S-AMG
should i get filters too?
Old 07-19-2011, 01:52 PM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
I had the BMC filters and threw them out, they set off my CEL four times and the dealer had the car on the star diagnostics and the car was always running to lean, this would set off the CEL, I also had in fifth gear acceleration a hesititation and stuttering, since I have removed them everything is back to normal.
Old 07-19-2011, 04:51 PM
gstatus929's Avatar
2014 E63 S-AMG
so leave out the aftermarket bmc filters and just remove the charcoal filters for best free hp right?
Old 07-19-2011, 09:57 PM
1st amg's Avatar
According to many, removing the charcoals will not give you any noticeable HP difference, at least in the seat of your pants. The gains if any, are not worth it imo, others may "think" that there are gains, but in a car that produces 450 to 500hp, you will not notice. Its up to you, but I personally have tried along with many members who I know personally and we are of the same opinion. Give it a shot if you want to satisfy your curosity and you can be the judge.
Old 07-20-2011, 10:34 AM
iatacs19's Avatar
axe muderer with headlights
At least MPG improves a bit.
Old 09-19-2011, 05:23 PM
gstatus929's Avatar
2014 E63 S-AMG
DOES MPG REALLY IMPROVE?
Old 09-19-2011, 06:11 PM
SonnyakaPig's Avatar
MB
I believe aftermarket filters and charcoal delete improves mpg. This has been my experience.
Edit: I forgot to add that I also was using ROW box tops in addition to filters and charcal delete when I experienced the bump in mpg.
Old 09-24-2011, 09:59 PM
kingnash's Avatar
03 SL55
what is row box tops and do they make them for my cls63?
Old 02-26-2013, 04:56 PM
uclachan's Avatar
10E63
hello everyone,
Sorry to bring an old thread back but i have a question.
This removing charcoal filter affect smog in anyways? I heard that this is not an actual filter. it's a HC (hydrocarbon) absorption pad that absorb gasoline vapor hence cleaner environment. do you guys know if this is written somewhere? Without HC absorption pad (charcoal filter) will my car pass Smg? just curious. Thank you in advance!!!
Live in Cali. I hate C.A.R.B.
Old 02-26-2013, 09:06 PM
c63edition1's Avatar
2013 Fiat Abarth
2 things, how do the weistec filters compare to the BMC ones or the K&N's filter? also, where can i get the air box on the left in the picture above ? the less restrictive one
Quick Reply: help needed removing charcol filter in E63
