Retrofit A/C outlet
C43 AMG CAB & VIPER
Retrofit A/C outlet
Hi All,
So I recently purchased a 2011 C63 AMG (palladium silver) and I'm very pleased with it.
I got a great deal to take the one they had in stock which had the premium pachage but
not the A/C power outlet in the back which I would REALLY like to have had.
I wonder if it is possible to purchase the bits to retro fit this ?
I have searched quite a bit (dealer, google, forums etc.) and I have not found anything.
I'd like to fit it into the same spot as the original.
If all else fails, I can always carry an inverter around but I'd REALLY like to avoid that.
Thank you in advance for any help / tips...
2010 Irridium Silver MB C63 AMG Sedan
I don't think we ever got that option in the US. I know my car is FULLY loaded and they never gave me the option of having it...personally I wouldn't go through the trouble. Just go faster and roll the windows down...
As I recall my C63 has three A/C outlets, one in the rear compartment, inside the ashtray. One in the front ashtray, as one in the glove compartment. I don't recall one being in the trunk, but I believe their is one. I would need to take a look. Is this what your referring too?
C43 AMG CAB & VIPER
I'm reffering to the one that would be located in the center console in the little flip door next to the cigarette lighter 12v plug facing the 2 REAR passengers.
I think only the c250/350 elegance etc. came with the rear A/C unit control panel not the C63. The C63 never came with rear A/C control panel only the vents.
You should have a cigarette lighter in the front ashtray, a 12VDC 15A outlet in the glove box and a 12VDC 15A outlet in the rear ashtray. There are no AC power outlets in the car. Not sure but I think you will need to wire in an aftermarket inverter if you want AC power.
