Will these wheels fit
I need some help from some experts here on the C63 Forum.
will these wheels fit with these offsets.
19x8.5 et 42 and 19x9.5 et 48
Can anyone comment on these
and can i run 235 35 19 and a 265 30 19 without rubbing?
This set up will be fine with the 265/30 tires. 275/30 might be close with +48mm offset... but doable!!
12 M156 C204
if you are lowered (lets say with h&r springs), stick with 265 at the back would be much safer. if you are on stock height, 275 at the rear is fine.
235 or 245 will both run fine at the front even if you are lowered with the h&r springs.
