MMI cables
1 Post
2014 C63 AMG 507 sedan
MMI cables
Hi C63 community!
I recently purchased a 2011 C63 and it is equipped with the MMI (option code 518).
The interface cable for iPhone/iPod plus Aux plug was located in the glove box, but it won't charge my iPhone 4.
I used the search and was reading so many threads, but I
couldn't find one specific information:
I need the correct MB part # for the iPod connecting cable that actually charges the iPhone 4 ( 5V via USB instead of 12V) and the USB port cable!
I was told they come in a set of three, but my local MB dealership couldn't locate it!
If somebody with a US spec C-Class has all three cables ( iPod, AUX and USB), please post the part #, so I can go to the dealer and order it via part #! The manual search didn't work at the dealership!
Thank you for your help!
Best regards
SCD-1983
Best regards
SCD-1983
My wife has a Iphone 4 and it doesn't work on any of my two benzs (C63 or C300). We have the same option as you. I hope this helps you figure out.
As far is I pods, it works with an Ipod.
Mine are still sealed in the bag. Here is a link to the part online: https://www.getmercedesparts.com/oem...des-parts.html
You will have to put the part # in. Price will be cheaper than dealer MSRP.
Help request.
Hi, I've a c204 coupè, year 2014, NTG4.7 MMI in the glove box (option 518).
Do you know how I can connect a video source (composite RCA connector) to see a video in the monitor? I've heard that I need to buy a cable (3,5mm to 3xRCA) but where I need to connect it? Maybe using the MMI to AUX (3,5mm female connector)? This cable supports also video input?
Do you know if an AUDI AMI video cable (the connector is the same..) will works in the MB Interface?
Thanks for your help.
What's the word on being able to run video through the screen? I'm definitely interested in how to set this up
