C63 Oil Cooler
C63 Oil Cooler
Read in an article:
Addressing a crucial issue with regards to its oversized 6.2-litre M156 V8 engine, its oil temperature issues in a high dynamic load environment (such as a track day), C63 Black Series coupe gains the SLS’s 50% larger than standard oil cooler. It also runs appreciably stronger internals (forged pistons and conrods) and spins a toughened-up (and lighter) crankshaft sub assembly.
So does that mean we can use the SLS oil cooler and retrofit in the C63?
I am having big heating issues, esp when I went to the track. I hit a temp of 284F! i think the car went into limp mode
Fluid Motor Union has one that might work for you. Not sure about fitting a SLS cooler. Might have to risk buying one and seeing if you can shoehorn it in. Better to see if someone else figures it out.
Here is a thread about the Fluid Motor Union cooler
https://mbworld.org/forums/c63-amg-w...il-cooler.html
