Will C300 AMG wheels fit?
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
Wondering if the 17" AMG C300 wheels will fit over the brakes of the C63 for winter tires use.
The answer is definite NO, 17" wheels will not fit on the C63. The minimal size needed is the stock 18" or larger. The issue is the 17" wheels don't have the necessary inner wheel clearance needed to clear the rotors & calipers. Besides that, the spokes will hit the calipers, when you try to put it on.
Not sure on the C300 wheel but you can get 17's to fit a C63.
Okay, I have more information now. You can run 17" wheels and tires (drag radials) on the rear only, as the rotors and calipers are smaller, and require less clearance. But, I know for a fact that you can't run 17" on the front, due to the huge rotors and calipers require alot of inner wheel clearance, that 17" wheels don't provide, ie. Inner barrel.
Okay, I have more information now. You can run 17" wheels and tires on the rear only, as the rotors and calipers are smaller, and require less clearance. But, I know for a fact that you can't run 17" on the front, due to the huge rotors and calipers require alot of inner wheel clearance, that 17" wheels don't provide, ie. Inner barrel.
I don't have the C63 yest so I can't test the fit.
I'd like to confirm to see if my spare C300 winter rims will fit.
I guess the right 16" will fit the rear. See post #4
https://mbworld.org/forums/c63-amg-w...g-radials.html
Looks like Pit-Pony will have to wait and see on the C300 17" wheels.
