C63 AMG (W204) 2008 - 2015
Break Pads and Tires any recommendations in Socal ?
Old 09-20-2011, 10:02 PM
rnz1991's Avatar
AMG GTS
Alright so my car has 24xxx miles and i just finished Service A , the dealer tells me that my brake pad has 10 % on them and that my rotors are near the limit and that when the brake pads will wear off i would need to change rotors and brake pads. i didnt buy anything of what he was saying and just put it on my mind. i was wondering if anybody whose in Socal that can recommend a place where i can check and change my pads for a good price , dealer asked 850 for all pads including labor. ( front and rear ). he also mentioned that a humming sound that i can hear at low rpms is from my tires which felt weird , i know that my front tires are almost worn out, but my rear tires still have some grip and not worn off. so any recommendations on new tires , i currently have p-zero they have good grip but i dont like how they wore off easily. i prefer a medium life stock tires with acceptable grip. i heard yokohama tires are like that correct me if i am wrong.
Old 09-20-2011, 10:07 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
Irregardless, minus whale get brake pads for all intensive porpoises. Just think of the french benefits.
Old 09-22-2011, 07:54 PM
magzamg806's Avatar
09 C63 AMG
Changed all 4 to Michelin Pilot Super Sport about a month ago, pretty happy with it so far. Mine has over 30k miles and I haven't changed brake yet.
Old 09-22-2011, 08:02 PM
GHAZAN's Avatar
MBUSA
Your dealership is lying I bet. Just did a brake pad swap at 40k and I had 3 mm left on the pads and 1mm+ on the rotors. Pad swap for parts 3-400 and 1-200 for labor far less than 900 they want.
Old 09-24-2011, 09:40 PM
kingnash's Avatar
03 SL55
what is a service A? i need it done also my cls63 is at 55k miles
Old 09-24-2011, 09:51 PM
_AMG_'s Avatar
C63
You have a PM.
Old 09-24-2011, 09:56 PM
kingnash's Avatar
03 SL55
??? no i didnt get a pm from you
Old 09-24-2011, 11:14 PM
DD GT3 RD's Avatar
'11 C63 w/ P31
you got 24k miles out of your tires and thats not good??? I got about 5k out of my stock rears and 2nd set of rears is about toast near 5k. fronts lasted around 8 but they are far gone
fronts
Old 09-24-2011, 11:47 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
Originally Posted by DD GT3 RD
^ Prematurely toasted. Was that from Buttonwillow? :)
How much static camber are you running?
Old 09-24-2011, 11:50 PM
DD GT3 RD's Avatar
'11 C63 w/ P31
from a willow springs, buttonwillow and willow springs again. They were looking bad after button willow but still driving on them and hit willow springs private track day a week ago, was only there for a couple hours thou.
running stock alignment. The front tires just get killed from all the weight up front. Back wore out much more evenly.
Surprisingly the pads got lots of life left
Old 09-25-2011, 12:07 AM
Super Moderator
splinter's Avatar
Indeed. I’ve witnessed you getting after it.
Wasted many a decent LF Michelin chasing the fast guys through 2 and 8 at Willow Springs before cranking in sufficient (~2.5°) negative camber.
Old 09-25-2011, 04:16 PM
c63canada's Avatar
c63 amg
if toure at 24 000 miles i don't see hw you could only have 10% left on your pads if you didn't track the car or drive like crazy. But you can easily check for yourself the thickness of the brake pads by just looking at them through the wheek spokes.
for tires think of michelin super sport since they have a mileage warranty.
Old 09-25-2011, 06:05 PM
rnz1991's Avatar
AMG GTS
Alright fellos, sorry to reply so late i checked my pads outside the dealership and the mechanic said you have atleast 40 ~ 60 % left **** the dealership. but , the mechanic said i need alignment so bad that my front tires are only eaten in the side. so i changed my tires and put on continentals DWs for around 870 for all 4 $ but there not 2011 tires.
Service A is mainly changing oil , cleaning filters and checking if everything is ok. cost me around 199 in the dealership.
Old 09-25-2011, 06:10 PM
Merc63's Avatar
C63 AMG
Don't change your brakes pads till the light comes on, unless you have $$ to burn...
Why change them when they aren't worn down?
Mine are low too, but I am waiting for that little light to come on before I touch them. Especially at the price for rotors and pads.... Cha ching!!
I ordered some Portfeild RS4 pads from www.formymercedes.com - the guy was really helpful and tells me these pads will last longer then stock with less noise. They are also a bit cheaper as well.
Old 09-25-2011, 07:49 PM
SonnyakaPig's Avatar
MB
I like to change pads when the braking capabilities begins to wane. I don't like driving around with pads that aren't up to snuff. But, it sounds like second mechanic told you that you have plenty of life left so that's good. And like others have said, it's very easy to visually inspect the pads to see how much life is left. Just look through the wheels at the pads.
For tires, I'm riding on Michelin PSS's and I'm really loving them. I'll get them again for sure.
I once sat in a deposition and listened to a defendant who rear ended a plaintiff admit that he never changed his brake pads in the life of his car, which was 150,000 miles. No joke. The look on the defense lawyer's face was priceless.
Old 09-25-2011, 07:52 PM
nasser's Avatar
2013 sl63 amg pp
Changing the brake pads very late doesn't effect the disc ?
Old 09-26-2011, 02:06 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
For street use, wait for the light to turn on.
No, it will not hurt the disk. These did not.
Cheapest way is to change them yourself with OEM pads from an online house. The rears only need a drift pin and a hammer. The fronts add a single bolt. Really easy. Just careful about the brake fluid overflowing in the reserviour if you have ever topped it off.
Old 09-26-2011, 07:26 PM
Merc63's Avatar
C63 AMG
I am told you are supposed to replace the rotors with the pads... Unless you have a caliper to measure rotor wear. But Mercedes will replace both rotor and pad at the same time they don't machine them.
Old 09-26-2011, 11:21 PM
No, you do not need to do that. Buy the caliper to measure, about $49 for the accuracy you need here.
I am on my second set of pads front and rear, and it was only after a heavy session on track, and 75k miles, that I went below min rotor thickness. It looks like this:
Even so, I am not running to replace the rotors until another track days comes up. Realize the over design of these brakes relative to normal daily driving. You still have more capability than the E350/C350.
Old 09-27-2011, 03:45 PM
kent426's Avatar
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
fronts
Stock alignment is doing that to your car. You need at least a 1.5 degrees negative camber, you'll be amazed how the car handles after. KMAC has bushings for the car.
https://mbworld.org/forums/c32-amg-c...ggestions.html
see my thumb there of my front tire wear at the track, ignore the harse outer wear as that was a toe in issue that caused that.
Old 09-27-2011, 04:53 PM
DD GT3 RD's Avatar
'11 C63 w/ P31
thanks! Ive decided im not modding the car thou. But if anything it will be some camber plates and KW's
Old 09-27-2011, 11:08 PM
Merc63's Avatar
C63 AMG
Just the man I want to talk to...
Did you get the rotors machined when you put new pads on? Or just replaced pads and left the rotors alone?
There is little wear indicators drilled into the rotors. Were those completely wore away?
I was going to measure mine as my tech friend at the dealer gave me the min measurements that benz says the rotors are good for.. They are awfully thick in comparison to other after market rotors..
Old 09-29-2011, 04:03 AM
No, just put on new pads. Did that at Thunderhill racetrack. Search for that post.
I am not familiar with any wear indicators.
The minimum thickness is indicated on the rotor.
Also, I am not sure, but I do not think cross drilled rotors can be turned. No real need to turn a rotor unless it is warped.
Old 09-29-2011, 03:43 PM
kingnash's Avatar
03 SL55
whats a SERVICE A? i need one due also
Quick Reply: Break Pads and Tires any recommendations in Socal ?
