2010 c63 Decat exhaust, Engine light?
2010 c63
anyone decatted their exhaust? does the check engine light come on? Anyone know how to bypass or prevent it from coming on? and also when in manual gear, shifting up , do you let off gas? like on the bmw smg transmissions?
You will get CEL if you remove the primaries, to turn it off you will need to tune the car.
If your removing 2ndary cats then you don't have to worry about CEL.
As far as shifting goes, No you don't need to let off the gas when shifting up.
2010 c63
I have had both straight pipe and X pipe setups (both with resonator delete)
Straight pipes are WAY louder, and much closer to LTH's imo.
2010 c63
2010 C63, 2007 X5
I removed my secondary cat, no CEL, and was louder. If you remove the first cat (called Primary Cats) you will have CEL, then you need a tune to remove CEL.
For those interested in what X pipe + resonator delete (straight pipes) sounds like.
http://www.youtube.com/watch?v=Ws3lFoqD2mo
