Need recommendations on AutoEnginuity code scanner and others (Actron)
1 Post
2008 C63 Sedan
So my CE light is on - most probably need to change my intake manifold gaskets. I've toyed with the idea over the years off getting a code reader / scanner.
I basically need it for the following:
1. Reading CE codes
2. Resetting them
3. Resetting service / oil change indicators if I do the service myself
I'm moderately handy but but certainly not shadetree mechanic level - so if anyone has experience with the AutoEnginuity - is it overkill for what I want to do - for example, I'll most likely never actually try to change any settings or do any tuning myself.
Also, is it easy to use like a handlheld scanner where you simply plug in, read the code, and then reset or is it not as intuitive.
1. Reading CE codes
2. Resetting them
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
I can tell you that Actron CP9575 does not work on our cars, even after a download of the update. I returned the one I purchased and have used a loaner from Pep Boys or Advance Auto to read and clear a couple of codes. I need to go ahead and buy one (that works).
^ what not to do.
what you can do > HHughes recommended this one to me in a previous thread:
http://www.harborfreight.com/obd-ii-...ner-99722.html
1 Post
2008 C63 Sedan
Checked that one out and the reviews aren't that great - several instances of it working for a while and then dying...With your Actron 9575 when you called Actron did they straight up acknowledge that it doesn't work with the W204? I called yesterday and had a bad connection but the guy started along the line of "...all our scanners work with OBD II cars..." If I get that line again then I'll also be suspect and may just go for the AutoEnginuity
09 c63 p30 mars red
2013 Chevy 427 Torch Red
Factory service reminders can be reset with the steering wheel buttons if you know the procedure which I don't.
