18x8.5 et48 fit C63
18x8.5 et48 fit C63
My friend is trying to selling me his wheels cheap for my winter wheels. The size is 18x8.5 et48mm 5-112, will these wheels can fit to my C63? Btw I have winter tires and the size is 235/40/18, it shouldn't have problem to mount it on these wheels right? thank you guys.
offset wise it won't stick out of the fender, but it's hard to tell if it'll clear the brake calipers without test fitting. If possible try to test fit the rim and see if it clears your calipers.
make sure you test both the fronts and rears since i'm not sure which wheel requires more brake clearance.
be sure to test fit them before you buy them. If you don't have a jack, simply use the emergency jack in the trunk. the clearance for the brake calipers is the big problem so depending on the design of the wheel they could fit or not.
