CAR NOT HANDLING WELL?
Former Vendor of MBWorld
Bring your car in for an alignment. We have a state of the art 4 wheel laser guided alignment rack and we can perform an alignment getting every wheel on your car within spec. Have you done any suspension work on your car and never had it aligned? You will be surprised how a small change in the suspensions geometry can negatively change the characteristics of teh car when not adjusted correctly.
This is not an alignment by your local tire shop that wants to make sure the car is going straight and the wheel is centered. Getting that stuff correct is easy but that is only a small part of the battle. There is a lot to your cars suspension and it is important to make sure that all 4 corners are correct.
If you have any doubt, give me a call and make an appointment to have your car straightened out.
OIL CHANGE SPECIAL WITH ALIGNMENT
If you need an oil change and want to get one done while it is on the alignment rack we are offering a special price of $119.00
This include an original equipment oil filter and synthetic oil.
Great opportunity to kill two birds with one stone.
Hey RPM,
Do you guys do corner balancing for cars on coilovers? Also, custom alignments, if I give you a specific set of camber/toe specs, will you set that up for me?
Thanks.
Thanks.
Just let me know when you would like to come on in and I will get you set up right away.
