C63 AMG (W204) 2008 - 2015
Oil Consumption Question
Old 12-08-2011, 01:00 AM
DKubicki's Avatar
C63 AMG
My 09 seems to be burning about 1.5qts every 1000 miles or so. It has about 19,000 miles on it. I took into the dealer today to top off because I was getting the check oil warning, and the SA seemed to think that it was burning a bit more oil than normal. He said he would like to do what he called a "consumption test" where they top off the oil and run the car for 60 miles and measure how much oil is burned. He claimed that if it was below a certain level there is a serious issue with the engine and that more than likely it would be replaced under warranty.
Has anyone ever heard of this?
If the engine is replaced does anyone know if this would have a negative effect on my resale value?
Old 12-08-2011, 01:34 AM
drawde's Avatar
2009 C63
How hard are you driving it? I'd say most of us keep bottles of oil handy to dump in there every now and then but 1.5qt every 1k is a lot imo.
Old 12-08-2011, 01:39 AM
DKubicki's Avatar
C63 AMG
Originally Posted by drawde
How hard are you driving it? I'd say most of us keep bottles of oil to dump in there every now and then but 1.5qt every 1k is a lot imo.
I wouldn't say I drive it very hard, just normal stop light fun.
Old 12-08-2011, 06:30 AM
JimmyR's Avatar
E63S
Does seem a little high especially as at 19000miles the motor should be fully run in.
Sounds like the dealer is working with you on this which is a good thing (though I would question the accuracy of their consumption test after just 60 miles of driving).
Old 12-08-2011, 08:29 AM
blownS's Avatar
'12 CTS-V
While these motors are notorious for consuming oil, 1.5 qts/1K miles is crazy. Mine usually requires a qt every 5-6K miles or so.
Old 12-08-2011, 11:03 AM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
This is a normal procedure that the dealership does, to evaluate oil consumption. This will tell them, whether there's an issue or not.
Old 12-08-2011, 11:42 AM
DKubicki's Avatar
C63 AMG
Thanks for the help! I took it in today, should know something by the weekend. I will let you all know what the outcome is.
Old 12-08-2011, 11:46 AM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
My 63 burns about a quart every 1000 miles or so, so your 1.5 doesnt seem too far off but slightly high.
Old 12-08-2011, 12:21 PM
Yuille36's Avatar
AMG has stated that it's not uncommon for their engines to burn 1qt for every 1000 miles. Porsche's are worse than us. But 1.5 qts is a bit much, I think. Both my C63 and E63 use about 1/2 - 3/4 qt between oil changes, so I'm very fortunate. I just added 1/2 qt to my C63 last week, and I'm due for a oil service in 1700 miles.
Old 12-08-2011, 04:16 PM
KINGPIN 007's Avatar
2010 c63
I had a similar problem where my oil light came on 1500 miles after getting an oil change done. They topped it off and the oil light came on again a month later (about 1000 miles) and so i took it into service and turns out the oil sensor that read the oil level went bad, so they replaced it under warranty. Maybe thats what could be happening here?
Old 12-08-2011, 04:21 PM
AMG-010's Avatar
2017 AMG C43
My car was using a bit of oil up to the first service. The dealer replaced the Mobil 1 0-40 with Shell Helix 5-40 and it hasn't used any in 6,000km.
Old 12-08-2011, 06:24 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
When I drive it normal it doesnt use any oil. After a drag day. Oil level goes down. C63 has 22K+ now.
Old 12-09-2011, 10:43 AM
Yuille36's Avatar
Originally Posted by KINGPIN 007
I took it into service and turns out the oil sensor that read the oil level went bad, so they replaced it under warranty. Maybe thats what could be happening here?
I think that you maybe on to something here. That would explain the constant oil consumption that some are experiencing. But that brings up another issue, if the sensor was in fact bad, and you kept adding oil over and over. No you have way too much oil sitting in the pan, that could potentially blow oil seals and gasket.
Old 02-24-2012, 10:17 AM
DKubicki's Avatar
C63 AMG
So after two consumption tests (because the dealership did not have the MB certified measuring tool for the first test) it was determined that my car burns ALOT of oil. For the 600 miles it burned 2 quarts of oil. So the dealership has been authorized to replace pistons and bearings. Do you guys think I should be worried? I also asked to see if they might give me a extra year on the warranty. I know its a long shot but I thought I would give it a try.
Thanks for the advice!
Old 02-24-2012, 10:20 AM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Let them replace the new parts and have them run more tests. If that doesn't fix it, get a new engine. If that doesn't work, lemon it and get a new car.
Old 02-24-2012, 03:28 PM
Merc63's Avatar
C63 AMG
Well this doesn't sound right. Are they going to re-hone the cylinders too?? I doubt they have the equipment for this at the dealer. The cylinders definitely need to be re-honed for the rings to seat properly and to ensure the cylinders surfaces are in good condition.
Now your car is 1 engine 2 men lol. Doesnt that go against AMGs philosophy?
I'd say F that and ask them for a brand new complete bottom end from the factory...
You really want some mb techs rebuilding your engine that are used to doing everyday maintainence?
Old 02-24-2012, 03:30 PM
Merc63's Avatar
C63 AMG
And what is he supposed to drive while this 3-4 month process happens?
Get it fixed right the first time! New complete bottom end from factory or a new engine.
Old 02-24-2012, 03:54 PM
DKubicki's Avatar
C63 AMG
Yeah that is what I tried and the dealership was turned down by MB. The SA said the cylinder walls were fine and MB would not authorize the short block to be replaced. Also it was my understanding they would need to stamp a new block to match my VIN so that would take time I guess. I just came back from the dealership and saw my car in pieces so I am freaking out a bit!
Old 02-24-2012, 04:08 PM
Even Money's Avatar
'15 VW GTI
I would have it lemon'd. Try selling this in a few years with major engine internal work. You'll be screwed.
Old 02-24-2012, 04:25 PM
Merc63's Avatar
C63 AMG
If the cylinder walls are fine why is it burning oil then?? Why didn't the rings seal properly the first time the engine was assembled??
at 19,000 miles the cylinder hone may look good to the naked eye, but its worn down. Both the cylinder and rings wear into each other during beak in. How is this supposed to happen if the cylinders are already worn down?
The idea behind the hone is it creates an abrasive surface that wears smooth as the rings come in contact with it. The rings I believe are tapered so that they also wear nice and flat against the cylinder wall.
Without a good ring/cylinder seal, blow by creates excessive pressure in the block which pumps more oil into your intake to be burned off. Also, excessive oil is left on the cylinder walls being burned off too.
I'd drive the **** out of it as soon as you get it back. Break it in nice and hard. If that doesn't work, new engine time.
Old 02-24-2012, 05:50 PM
Merc63's Avatar
C63 AMG
My thoughts exactly, if you are trying to sell this car private and the buyer does service history at a dealer.. This info would be a dealer breaker for most buyers.. Unless you plan on trading this car into the dealer or its a lease return.
Old 02-24-2012, 11:42 PM
track_warrior's Avatar
Like The Stig
Lol i keep a quart of oil in my trunk all the time just in case since they do tend to consume a lot of oil i heard it gets better with time, though 1 quart per 1000 miles is a lot unless you tracked for 500 out of 1000 miles. My car puffs blue smoke on startups some days and some days it doesnt. Runs like a champ though.
Old 02-25-2012, 12:03 AM
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Question
Well, only knowing what's written here, I wouldn't be happy with pistons , rings & bearings either....particularly on such an expensive engine. BUT, if that's all M.B. will do...well, they'd be a big company to argue against wouldn't they?
So, what does the Dealer say is wrong, why is it using oil, are the rings worn, is the bore glazed, are there any marks in the bore, what has caused the problem?
If the O.P. could be supplied with answers to these sorts of questions, then maybe he would be better placed to know whether what M.B. is offereing will do the job.
What sort of relationship do you have with the Service Manager?...Do you think he's "on your side" & looking after you?
I must say, that at this stage, a new set of pistons, in simply a honed bore, does seem a little "light on" for this type of engine?
But maybe a good chat with your service manager can ease your concerns.
Cheers, Pickles.
Old 02-25-2012, 04:25 PM
Merc63's Avatar
C63 AMG
DKubicki: Can you update us on this thread as things progress with your car and what they are doing to fix it, etc..
Im interested to see what comes out of this and how MB handles this.. AND if replacing these parts is going to ultimately be the answer to your oil consumption. Thanks
Old 02-25-2012, 04:36 PM
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
+ 1 000 000 000
Quick Reply: Oil Consumption Question
