C63 AMG (W204) 2008 - 2015
Need help with wheel offset
Old 12-10-2011, 07:33 PM
Mikegpr03's Avatar
C63
Guys I might be getting some 20' wheels 20X8.5 front and 20X9.5 ( or 10 ) for the rears. What offset should the 20' wheels be ordered with? Also can you wheel guys suggest the proper ET for a set of 19's?
Wheels in question are
19' BBS CH-R's ( silver or titanium )
20' TSW NURBURGRING's ( Black )
Mike
Old 12-11-2011, 06:36 AM
Mikegpr03's Avatar
C63
Wheel guys need some help please
Old 12-11-2011, 07:15 AM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Sites,
Tirerack for BBS
TSW for NURBURGRING
Don't be lazy.
Old 12-11-2011, 07:36 AM
hyperion667's Avatar
Received 3,353 Likes on 2,807 Posts
2012 CLS63
yeah, don't be lazy, just curt and rude
Old 12-11-2011, 09:09 AM
Mikegpr03's Avatar
C63
Guys don't understand my question. I need the proper offset to run on the C63. I already did go to both websites. A 20' wheel needs a certain offset and tsw doesn't have a recommended 20inch ET for out cars, just for 19's.
Please do be so quick to judge
Old 12-11-2011, 09:19 AM
2012 CLS63
wasn't judging you know?
no disrespect!
Old 12-11-2011, 09:25 AM
gthal's Avatar
2012 C63 coupe
Diameter of the wheel is irrelevant. Offsets are the same subject to wheel width. A 20" wheel has a lower profile tire so overall diameter is the same, therefore offsets aren't impacted. If you change the width of the wheel, this may impact offset. That is, a wider wheel may often require a higher offset to maintain the same fender room. Many go with a 10" wide wheel and a 50 or 55 offset which results in a slightly more aggressive fitment than stock (which is 9" and 54 offset in the rear).
So... 20" size doesn't impact offset choice and if they don't have the right offset for the 20" size then you may be out of luck. Also, as mentioned, the width of the wheel and the tire choice will impact the offset. The combinations are many.
Old 12-11-2011, 09:56 AM
Mikegpr03's Avatar
C63
Thank you I was really looking high and low for this. Tsw has a 9.5 and a 10 inch wide wheel. I'd love to be as flush as possible. The rear wheels come in a ET 40 and ET 54
Old 12-11-2011, 10:03 AM
gthal's Avatar
2012 C63 coupe
You will rub with a 40 rear offset. I would go with ET54.
Old 02-07-2012, 08:58 PM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
Hey, did you ever try to fit 20's on your car.
I was thinking about 20's but don't want to change out my suspension.
Old 02-08-2012, 03:25 AM
bhamg's Avatar
C63 AMG
Read through the aftermarket wheel thread at the top...my guess is there is a ton of useful info re. ET's as well as lots of photos so you can fine tune the ET visually. Not a lot of us have gone to 20's so understandably don't want to make recommendations shooting from the hip.
Old 02-08-2012, 09:23 AM
I just want to try to fill the wheel wells without changing my suspension.
Old 02-08-2012, 09:30 AM
noodleman's Avatar
2014 E63S Wagon
gthal already answered your question in terms of offset, but what you also need to make sure is that the pad clearance on the wheel will clear our gigantic rear brakes.
Quick Reply: Need help with wheel offset
