Engine Cleaning? - I'm an extreme idiot
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I Topped off my oil... and drove off..... forgettingthe oil cap... fortunately, it was still where I left it 10 miles later... and I had 4 quarts of oil in the trunk. However... there is oil EVERYWHERE....
Any ideas on how to clean it...
Side problem is that 2 days ago a CEL popped... which was shy I checked my oil andother fluids. Warranty does not cover stupidity... want to clean it before I go to the dealer in the morning.
2010 Irridium Silver MB C63 AMG Sedan
Jvan your just gonna have spend a few hours cleaning it. Sorry it happened. Start now and put on some good John Denver or Neal Diamond and get it going...GL
I did this as well... Never felt dumber...
Anyways, I just took it to a public wash bay, and sprayed the engine with a pressure washer. All the oil drained away. Really didn't cause any problems. Engine had never been cleaner.
09 c63 p30 mars red
No permanent damage! You not the first one to do this. Simple green a brush and a slow running hose. Don't sweat it too much. Try to be careful around the wiring.
Probably too late but here's what I have done in a similar situation and recommend:
- Do NOT use a pressure washer, whether home or commercial. Water will get into places where it shouldn't.
- Use hot water from a garden hose w/o a nozzle and gently rinse the engine compartment from above - not from the side - until the run-off water trail shows significantly less of an oil slick.
- Use a spray bottle filled with a not very aggressive cleaner (I generally use a glass cleaner) and spray the affected areas thoroughly.
- Repeat the hot water rinse
- Pay particular attention to the spark plug wells to dry them out - you will have a rusty mess later if the water sits there for a period of time.
I managed to get it clean.
I did use some of the more toxic stuff out there.. sprayed it down, then sprayed that stuff off lightly with water. Then I used my foam gun, with a light coating of car shampoo, then cleaned that off with a light spray of water.
Engine looks brand spanking new now.
I also used a hair dryer on all of the electronic parts in the bay, then went for a spirited drive to dry out the engine bay completely.
