C63 AMG (W204) 2008 - 2015
H&R Springs, to get the 17mm spring pad or no
Old 01-31-2012, 10:54 AM
noodleman's Avatar
2014 E63S Wagon
just ordered the H&R springs, debating if i should just reusing the stock rear spring pads or get the thicker ones to get a more even drop.
Does anyone have pics of the H&R springs drop with and without the new spring pads?
Old 01-31-2012, 11:47 AM
Raygt3's Avatar
2012 E550 Cab
In the same boat. Anyone have MB P/N's for these pads? Do we need thinner or thicker ones to produce additional drop?
Tnx
Old 01-31-2012, 12:09 PM
noodleman's Avatar
2014 E63S Wagon
spring pads A 210 325 04 84
They don't produce an additional drop, rather raise the rear up a tad to produce a more even looking drop from what i've read.
Old 01-31-2012, 04:09 PM
604 C63's Avatar
2012 E550 Cabrio
You mean otherwise it looks like the butt sags?
Old 01-31-2012, 04:15 PM
JeffDL's Avatar
C63
reused stock ones.
Old 01-31-2012, 05:02 PM
Mikegpr03's Avatar
C63
If you use the stock pads the car with have a level drop. The issue is that the fender well is at different hieghts so the car will look like the rear is slammed. Trust me I went thru the HR springs and ended up with coil overs in the end only to finally trouble shoot the odd "clunk " every one gets which by the way is fixed with a $.25 washer. Get the thicker pad 12-17 so the car looks even.
Old 01-31-2012, 05:15 PM
noodleman's Avatar
2014 E63S Wagon
Borrowing JeffDL's pic. Looks pretty good with the stock pads.
Rowell's car with the 17mm pads
tough choice.
Old 01-31-2012, 05:47 PM
Raygt3's Avatar
2012 E550 Cab
+1 on the thicker pads, P/N? Could you elaborate on the washer fix? I can afford a couple of washers. Just a heads up as to what I need to do. Tnx
Old 01-31-2012, 07:42 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Yep, im using the thicker pads cuz i didnt like to see the car higher in the front. Now the drop is even. Plus it saved me from rubbing since i have aggressive offset wheels with 275 tires in the back. The pads are so cheap at the dealership (20$) for a pair.
Old 01-31-2012, 08:01 PM
izzyAMG's Avatar
2019 GLC63, 2020 M2 Comp, 96 Miata M Edition & 19 Forester
Anyone tried just dropping the fronts?
Old 01-31-2012, 09:02 PM
Mikegpr03's Avatar
C63
tough choice.
The 1st pic really doesn't do the rear drop much justice since there a lot of shade in the pic. As you can see the 2nd pic the car looks even. Also as the car rolls these cars tend to drop a bit. My 0.2 is go with the thicker 17 mm pads.
Old 01-31-2012, 09:22 PM
M Thrizzle's Avatar
2008 M3
Hows the ride with the h&r springs? R u riding on the bump stops?
Old 02-12-2012, 04:40 PM
twelvehundred's Avatar
2014 C63
Used stock pads.
Just installed yesterday at FX. Drop looks good. I'm keeping my eye on the rear as it settles.
Old 02-12-2012, 06:45 PM
Roswell's Avatar
Nice move, I got my springs from them as well. Excellent service! As for the stock pads, it won't settle that much so u will be fine. Love the look & the ride is as good as stock, just a bit lower.
Old 02-12-2012, 09:12 PM
2014 C63
Alignment?
Did those of you with H&Rs installed get an alignment right away? I only have 3k miles on the car but will get the alignment if it will extend the life of these tires.
Old 02-12-2012, 09:32 PM
Roswell's Avatar
I didnt do my alignment yet, and it's been almost a year now since the install. But my car doesnt pull left or right so I'm not worry at this point.
Old 02-13-2012, 12:27 AM
Pakeboy's Avatar
'06 C230 SS
thanx for answering the questions for me...lowering mine this weekend and using the stock pads...
Old 03-08-2012, 11:38 PM
Shellbmb's Avatar
14 GL550; 14 E63s
https://mbworld.org/forums/c63-amg-w...e-lowered.html
Is this what you mean by the rear looking "slammed"? Sounds like the stock pads were re-used in this thread.
I am considering using H&R sport springs, but I don't want the rear to look any less aggressive that it already does.
Old 07-11-2017, 09:24 PM
AzItaliaC32's Avatar
2002 C32 AMG Kompressor, 2012 E550
Coilover and spring pad don't fit together
So I got HR coilovers installed and bought the bigger spring pad from mb dealer. Picked up the car and my mechanic who had done many installs and work on all my cars shows me it doesn't fit together. The spring pad has an inner diameter that doesn't fit with the metal adjustment screw collar at top of coil over, so he just used the newer pad and left off the adjustment screw collar at the top. Thread after thread says use the pad with the coil overs, but how? They do not fit into each other? Car doesn't look bad but rear is tucjed under fender about quarter inch and front is about right at tire..??
Old 07-11-2017, 09:37 PM
chrisridebike8's Avatar
'10 C63
I thought the spring pads were for spring installs, not coilover installs. Someone correct me if I am wrong
Old 07-11-2017, 10:06 PM
Jasonoff's Avatar
Received 1,572 Likes on 925 Posts
2010 C63 AMG
Coilivers are only in the front.
Old 07-12-2017, 12:13 AM
'10 C63
Jasonoff, thanks for the pic. Now that I can see it, that makes sense. The springs look like they would still need a pad at the top. I think the 17mm ones wouldn't be needed since you can just adjust the ride height.
Old 07-12-2017, 09:04 AM
Jasonoff's Avatar
2010 C63 AMG
Looks like they already come with a set. They're in the pic.
Old 07-12-2017, 03:23 PM
Mort's Avatar
You can't use springs pads with the rear springs in a coilover set. The rear springs come with adjustable collars that sit on top of the springs and mount to the cup on the body of the car and the rear spring pads are removed all together.
OP get the idiot who did your install to reinstall the adjustable collars on top of the rear springs and properly adjust the rear to the height of the coilovers on the front of the car.
Old 12-19-2019, 07:04 AM
Paul Last's Avatar
W204
where can I buy 17mm stock pads plz
Quick Reply: H&R Springs, to get the 17mm spring pad or no
