C63 AMG (W204) 2008 - 2015
CEL - help me.....
Old 02-01-2012, 05:51 PM
id64's Avatar
AMG C63, Merc C230, Audi A3
Thumbs down CEL - help me.....
I am not sure what's going on, but this engine light thing never goes away. System running lean, trip to the dealer, coming back etc etc. Once it was a gasket, after they've replaced mafs, purge valve and did 100 diagnostics. Now, it's on again for almost 2 moths, firstly to was going away for couple of days, but always coming back. Took it to the dealer and they said there was a purge valve. They fixed it at my expense since car is no longer on the warranty. It came back this afternoon again. Obviously, I am pissed at MB, AMG, but I need some cool headed advise - WHAT TO DO?
TIA
Old 02-01-2012, 05:55 PM
Even Money's Avatar
'15 VW GTI
Have a tune or any mods?
Old 02-01-2012, 06:02 PM
_AMG_'s Avatar
C63
Hook up a diagnostics computer through the OBDII port and see what codes you pull up.
Old 02-01-2012, 06:18 PM
id64's Avatar
Nope. All stock.
Old 02-01-2012, 06:25 PM
Even Money's Avatar
'15 VW GTI
I think if you google purge valve and mbworld, there is some history of purge valve issues.
Old 02-01-2012, 06:32 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
What year is your car? What kind of gas are you using?
Old 02-01-2012, 07:24 PM
Leon Bacon's Avatar
Location: Southern Maryland, about 50 miles out of D.C.
16 C63S
I had similar issue, but I have a Kleeman tune and headers. Codes read lean left and right bank. I removed the K&N air filters, put stock filters back in, cleared codes and seems to have worked. CEL been out for hundred miles so far.
Old 02-01-2012, 07:39 PM
Merc63's Avatar
C63 AMG
Was the intake manifold gasket replaced?
There is a new part number for the purge valve, as the original one wasn't manufactured to spec. If your IM gasket was replaced and so was the valve, then maybe they used the old spec valve again?
Old 02-01-2012, 08:58 PM
jarjoug's Avatar
2006 BMW 330i, 2009 C63
If the gasket was not replaced, it might still be leaking. I had the same problem for 2 months.
George
Old 02-01-2012, 09:19 PM
id64's Avatar
George
It was replaced a year ago
Old 02-01-2012, 09:38 PM
Merc63's Avatar
C63 AMG
Get them to check it again. It might be leaking again then. Its simple to check, they spray a flammable fluid around it and check the idle.
Old 02-01-2012, 09:42 PM
Helms's Avatar
C63 AMG
definitely get it checked again, it might still be leaking as the guys said above.
Old 02-01-2012, 09:49 PM
C63newdude's Avatar
C63 AMG
You don't think that the dealer has done that already? I mean, I have a OBD II diagnostic tool which is very handy but it would make no sense to me for the dealer to not use it on their diagnostic
Old 02-01-2012, 09:52 PM
Merc63's Avatar
C63 AMG
I dont think he read it completely.. Like me I just scanned through it, posted, then realized after he noted the code as running lean...
Quick Reply: CEL - help me.....
