1/4 Mile run Auto or Paddle??
Hello guys!
Please help me figure out what is the most efficient way to have the best possible run.
2009 C63 P30 Pkg
Drop in K&N, and
Ecu flashed
Dyno'd 435 rwhp / 393 rwtq
Stock wheels
Paddle shifting, I ran this week a 12.2 @ 116
Thanks!
2009 C63 P30 Pkg
Drop in K&N, and
Ecu flashed
Stock wheels
Thanks!
I would have to say the Sport mode because it is very consistent. The manual mode is more of a miss than hit. You would have to practice a lot and even like that you would never be as consistent although if you shift perfectly well you will end up with higher traps and lower ET.
As to the OP's question:
Manual Paddle shift is better. Its a much quicker shift but you need to figure out when to shift or you will hit the rev limiter. If you are looking to shave 100's off your time Manual Mode is the way to do it.
Got it. Interesting. I wonder how this applies to the MCT transmission? Manual still quicker?
On my 09 there is no question that the M shifts are much quicker, you are right.
The MCT in S+ mode probably shifts just as quick as the 7G in manual mode and even quicker in manual mode. The gear ratios are also slightly different in the MCT. The difference in shift times between the C mode to S is 20 percent. S+ is another 20 percent from S+ to M mode is another 10 percent. So the difference from C to M in the MCT is a 50% quicker shift.
