Engine Oil Question
C63 AMG
Engine Oil Question
Guys I want to start using Royal Purple HPS but they dont have 0W40 they only have 10W40, and they have the 5W40 on the normal Oil from royal purple! So is it ok to use 10W40 from our original 0W40? and by the way we have very hot climate here in the middle east, but at the moment its quiet cold we're reaching 10C as lowest tepmrature! please help me out with this issue because i really want to use Royal purple as i heard its a very good well recomended oil special for hard driving!
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
Mobil 1 = hard driving. With regular changes every 5000/7000Kms, very hard driving 5000Kms and your very hot climate will be fine.
Royal Purple is garbage for a C63.
C63 AMG
Is royal purple that bad for our engines? ive heard good stuff about royal purple! do u really not recommend it ?
1 Post
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
Oh,oh, here we go again with the oil thing. People swear by Royal Purple and other oils as well.I myself have used Mobil 1 for ever and have had no problems, Mercedes and Porsche have developed and tested their powerplants with Mobil 1 in the harshest enviroments as well as the engine test stands.
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Geez.......oils?????!
Everyone will have an "opinion" here.......and they'll probably all be pretty much correct, because most recognized "brand" oils, Mobil, Castrol or whatever are pretty good.
Cheers, Pickles.
Cheers, Pickles.
"Search" and you will find.
AMG aswell as DTM, don't use Royal Purple, they use Mobil 1.
Royal Purple has additives that hurt the C63's engine in short term use.
Kindly search for the factual data, it is on this forum.
When it comes to oil brand matters very little. Its viscosity and certifications that matter.
0W40 will provide better hot and cold operating performance than 10W40. If Royal Purple doesn't meet all the recommended MB certifications avoid it.
C63 AMG
thanks guys! i appreciate your replies, but i seriously thought royal purple was a good oil because of its synrelc in the oil, also heard provides better performance! so nobody ever tried it on the 63 engines??
C63 AMG
guys just got this reply from royal purple!!
Good afternoon Mohammed,
For your 2009 Mercedes AMG C63 the Royal Purple oil with the absolute best protection and performance is Royal Purple XPR 10W-40 (part #01021, quart bottle). Even though this is our racing oil and not a warranty compliant API licensed oil, it can be used safely with catalytic converters in street use applications for decades without issue.
The next best is our new Royal Purple HPS 10W-40 (part #31140, quart bottle), The HPS series because it has a significant portion of the XPR protection yet is priced closer to the RP SAE/API street oils is without a doubt the bang for the buck winner in this comparison.
The next suggestion would be for someone who absolutely needed an API licensed oil in order to be warranty compliant with a fairly new vehicle. The best protection and best choice within our SAE street oils for your 09 AMG C63 is Royal Purple SAE 5W-40 (part #01540, quart bottle).
Your 2009 C63 AMG takes 9.3 quarts.
Due to Royal Purple HPS being a new product this year, you are not likely to find it on a local store shelf. However eventually a special order should be possible at your local O’Reilly’s, or NAPA. Also in some regions Advanced Auto, Carquest and Pep Boys may also be able to special order HPS for you.
When getting HPS locally does not work out it is definitely available and shipping online at:
Amazon.com:
Lucky7trucks.com: http://www.lucky7trucks.com/_e/dept/08-001-011/HPS_High_Performance_Street_Oil.htm
Summit Racing: http://www.summitracing.com/search/brand/Royal-Purple/?autoview=ProductName
Jegs: http://www.jegs.com/i/Royal+Purple/831/31130/10002/-1
Pace Performance: http://paceperformance.com/search.html?q=royal+purple&go=Search
Thank you for choosing Royal Purple and have a great day!
Jim Morrissey
Technical Services
Amazon.com:
Jim Morrissey
Technical Services
Are you sure you can't pick an oil from this list?
229.5 Multigrade engine oils (Specification 229.5)
For use in vehicles/engines refer to Sheet 223.2
Last update: 02/06/2012
PRODUCTNAME 0W-30 0W-40 5W-30 5W-40 PRINCIPAL
8100 X-cess MOTUL SAE 5W40 x Motul , AUBERVILLIERS CEDEX/FRANCE
ADDINOL SUPER POWER MV 0537 x Addinol Lube Oil GmbH, Leuna/Deutschland
AeroShell Oil Diesel Ultra x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Agip SYNTHETIC PC SAE 5W-40 x ENI S.p.A. - Refining & Marketing Division, ROM/ITALY
ALPINE Longlife SAE 5W-30 x Mitan Mineralöl GmbH, Ankum/Deutschland
Alpine RS 0W40 x Mitan Mineralöl GmbH, Ankum/Deutschland
ARAL HIGH TRONIC M SAE 5W-40 x Aral Aktiengesellschaft, Hamburg/Deutschland
ARAL HighTronic M SAE 5W-30 x Aral Aktiengesellschaft, Hamburg/Deutschland
ARAL SUPER TRONIC G x Aral Aktiengesellschaft, Hamburg/Deutschland
ARAL SuperSynth x Aral Aktiengesellschaft, Hamburg/Deutschland
ASTRIS MAGIS SAE 5W-40 x Astris S.A., 6745 GIORNICO/Schweiz
AVIASYNTH 5W-40 x Avia Mineralöl-AG, München/Deutschland
Biloxxi 5W-30 x MCC Trading Deutschland GmbH, Düsseldorf/Deutschland
bp superV Plus 5W-40 x BP p.l.c., LONDON/UNITED KINGDOM
bp Visco 5000 5W-30 x BP p.l.c., LONDON/UNITED KINGDOM
Castrol EDGE 0W-30 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Edge 0W-40 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE 5W-30 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE Professional A3 0W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE Professional A3 0W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Edge Professional A3 5W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE PROFESSIONAL A3 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE Professional Diesel 5W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE TITANIUM 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Edge with SPT SAE 0W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Magnatec Professional A3 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol SLX Professional Longtec 0W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
CEPSA star 5W40 SYNTHETIC x Cepsa Lubricantes, S.A., MADRID/SPAIN
Cepsa Star Mega Synthetic 0W-30 x Cepsa Lubricantes, S.A., MADRID/SPAIN
Chevron Supreme Synthetic Motor Oil x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
Consol Ultra x Vial Oil Ltd., FRYAZINO, Moscow region/RUSSIA
Divinol syntholight MBX SAE 5W-30 x Zeller+Gmelin GmbH & Co. KG, Eislingen/Deutschland
elf EXCELLIUM 0W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Elf Excellium Full Tech 0W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Elf Excellium Full-Tech 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Elf Excellium Full-Tech 5W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Engen Xtreme Syn 5W-40 x Engen Petroleum Ltd., JOHANNESBURG 2000/REPUBLIC of SOUTHAFRICA
Everyday Full Synthetic 5W-40 x Penrite Oil Company Pty Ltd, WANTIRNA SOUTH/AUSTRALIA
EVOLUTION OEM Series I 5W-30 x TOP 1 Oil Products, San Mateo, CA/USA
EVOLUTION OEM Series I 5W-40 x TOP 1 Oil Products, San Mateo, CA/USA
Fastroil Premium Plus SAE 5W-40 x HILL Corporation, Shymkent/KAZAKHSTAN
Fina FIRST 600 0W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Fuchs TITAN Supersyn LONGLIFE 5W-40 x Fuchs Petrolub AG, Mannheim/Deutschland
Fuchs TITAN Supersyn Longlife SAE 5W-30 x Fuchs Petrolub AG, Mannheim/Deutschland
G-Energy F Synth 5W-30 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
G-Energy F Synth 5W-40 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
G-Energy Service Line MS 5W-30 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
GALP Active 3000 M 5W40 x Petrogal S.A., LISSABON/PORTUGAL
GALP FÓRMULA XLD SAE 5W-40 x Petrogal S.A., LISSABON/PORTUGAL
Gulf Formula GMX x Gulf Oil International, London/ENGLAND
Gulf Formula GX x x Gulf Oil International, London/ENGLAND
Havoline Ultra BM x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
LIQUI MOLY 5W-40 LEICHTLAUF HIGH TECH x Liqui Moly GmbH, Ulm/Deutschland
LOTOS SYNTHETIC PLUS SAE 5W40 x Grupa Lotos SA., GDANSK/POLAND
LOTOS SYNTHETIC TURBODIESEL PLUS 5W40 x Grupa Lotos SA., GDANSK/POLAND
LubriGold Full Synthetic 5W-40 x Warren Oil Company, Inc., WEST MEMPHIS, AR 72303-2048/USA
LUKOIL GENESIS 5W-40 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL LUXE MC x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL LUXE Synthetic x OOO LLK-International, MOSCOW/RUSSIA
master oil v-tec Premium 0W-40 x Interparts Autoteile GmbH, Stuttgart/Deutschland
MB 229.5 Motorenöl A 000 989 83 01 x Daimler AG, Stuttgart/Deutschland
megol Motorenoel High Condition x Meguin GmbH & Co. KG Mineraloelwerke, Saarlouis/Deutschland
Mercedes-Benz PKW-Synthetic Motorenöl Blatt 229.5 x Daimler AG, Stuttgart/Deutschland
Midland Synqron x Oel-Brack AG, HUNZENSCHWIL/Schweiz
Mitan Alpine RS 0W-40 x Mitan Mineralöl GmbH, Ankum/Deutschland
Mobil 1 0W-40 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil 1 Arctic 0W-40 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil 1 Formula M 5W-40 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil 1 New Life 0W-40 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil 1 Turbo Diesel 0W-40 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil SHC Formula MB 5W-30 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil Super 3000 Formula M 5W-30 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Motul 8100 X-max 5W-30 x Motul , AUBERVILLIERS CEDEX/FRANCE
Motul 8100 X-max 5W-40 x Motul , AUBERVILLIERS CEDEX/FRANCE
Motul Synergie Tech+ 5W40 x Motul , AUBERVILLIERS CEDEX/FRANCE
OMV BIXXOL special BM SAE 5W-40 x OMV Refining & Marketing GmbH, VIENNA/Österreich
Pennzoil Platinum European Formula x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
Pennzoil Platinum European Formula Ultra x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
Pennzoil Ultra Euro 5W-40 Full Synthetic x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
PENRITE HPR 5 5W-40 x Penrite Oil Company Pty Ltd, WANTIRNA SOUTH/AUSTRALIA
Pento High Performance 5W-30 x Deutsche Pentosin-Werke GmbH, Wedel/Deutschland
Premium Synthetik Motorenöl x Daimler AG, Stuttgart/Deutschland
Q European Engine Ultra x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
Q Horsepower Full Synthetic x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
Quaker State Synquest x Shell International Petroleum Company, LONDON/UNITED KINGDOM
RAVENOL HCL x Ravensberger Schmierstoffvertrieb GmbH, Werther/Deutschland
real,- Quality GSR 5W-30 x real,- Handels GmbH, Düsseldorf/Deutschland
REPSOL ELITE Common Rail 5W30 x Repsol YPF Lubricantes y Especialidades, S.A., MOSTOLES - MADRID/SPAIN
ROWE SYNT RS SAE 5W-30 HC-D x ROWE Mineralölwerk GmbH, Bubenheim/Deutschland
ROWE SYNT RS SAE 5W-40 HC-D x ROWE Mineralölwerk GmbH, Bubenheim/Deutschland
Shell Helix Diesel Ultra x x x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Diesel Ultra E x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix HX8 x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix HX8 C x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra x x x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra AB x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra C x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra E x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra Extra Polar x Shell International Petroleum Company, LONDON/UNITED KINGDOM
smart Motoröl 5W-30 x Daimler AG, Stuttgart/Deutschland
SRS ViVA 1 Longlife x SRS Schmierstoff Vertrieb GmbH, Salzbergen/Deutschland
Statoil LazerWay 5W-40 x Svenska Statoil AB, STOCKHOLM/SWEDEN
Statoil LazerWay TDI 5W-40 x Svenska Statoil AB, STOCKHOLM/SWEDEN
SynPower HST x The Valvoline Company, LEXINGTON, KY/USA
SYNTIUM 3000 x PETRONAS LUBRICANTS INTERNATIONAL, KUALA LAMPUR/MALAYSIA
TAMOIL SINT FUTURE RACING x Tamoil Italia S.p.A., MILANO/ITALY
TECAR Special M Motorenöl 5W-30 x Techno - Einkauf GmbH, Norderstedt/Deutschland
Texaco Havoline Synthetic Motor Oil x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
TNK Magnum Ultratec x TNK Lubricants, LLC, MOSCOW/RUSSIA
Total Activa Energy 9000 0W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz 9000 Energy 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz 9000 Energy 5W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz Energy 9000 0W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Valvoline SynPower 5W-40 x The Valvoline Company, LEXINGTON, KY/USA
Valvoline SynPower HST x The Valvoline Company, LEXINGTON, KY/USA
Westfalen Gigatron 0W-40 x Westfalen AG, Münster/Deutschland
YACCO VX 1600 0W30 x Yacco SAS, ST PIERRE LES ELBEUF/FRANCE
ZIC XQ 5W-30 x SK Lubricants, DAEJEON/Rep. of KOREA
Using an oil that doesn't meet the appropriate API specification just creates the risk of having a warranty claim denied. Go with a quality synthetic that meets the appropriate API specs. You won't be disappointed.
Amazon.com:
Jim Morrissey
Technical Services
Amazon.com:
Jim Morrissey
Technical Services
