Bent the factory lug wrench...
c63, 11 e350 (DD)
blah, I was taking my front wheels off to put on some spacers, and one lug was on so tight, after putting on gloves, I tried pulling with all force, I thought I nudged it, but ended up bending the lug wrench
I also have the 4 sided wrench, but the Mercedes lugs are too small for it, any wrench suggestions to make my life easier??
I recommend that you get yourself a extendable Gorilla Wrench. Lug Bolts aren't and issue anymore with this baby.
http://www.tirerack.com/accessories/...&brand=Gorilla
c63, 11 e350 (DD)
Cool, thanks guys!
c63, 11 e350 (DD)
If I remember correctly, I saw you mention you were a Mercedes tech in the past?
Question; I ordered extended bolts, for the spacers, they're "tapered" and not ball, what's the difference? Will I be fine?
http://www.ichibausa.com/ProductDeta...ode=ST-145401B
Thanks man!
Thanks man!
1 Post
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
I was told NOT to use a torque wrench to remove wheels... ONLY to install them. The logic was you could damage the calibration of the wrench removing lug bolts.
Also to the OP... I would expect the bolt was WAY over torqued if you had such trouble removing it. I would be careful to not over torque them on re-install.
2012 C63 AMG
Use a torque wrench only to set your lugs at a certain torque. Wouldn't recommend using it to remove them. Ball seats are normally found on OEM wheels while tapered seats are found mainly on aftermarket wheels. Like others have said, make sure you get the right set for your wheels. Get a 17mm deep socket and a breaker bar (got one at my local shop for $5) and you won't have any issues removing those bolts. Just make sure you get your jack set up and raise the car until the tire is just touching the ground and then loosen up the bolts. Once loose, raise it up and remove.
While technically you CAN use a torque wrench, it's not the best tool to use when removing your lug bolts. If you torque wrench is capable of handling the CCW torque without going over the range of the wrench, no damage will occur.
FYI, when you use the same length bolts that are conical seat vice the OEM that are ball seat, you will lose about 3 or 4 turns on seating the bolts which increases the chance of ripping them out, not to mention the uneven load bearing when the bolt isn't seated flush. Also expect when running slicks that tech will require the use of wheel studs/nuts to visually ensure the bolts are properly seated.
Impact guns or regular socket wrench's would be appropriate for removing lug bolts.
Guess who the Snap On/Matco guy recommended when one of his customer's torque wrench needed calibration?
Either way...torque wrench not the best tool to remove your lug bolts.
I'm glad I'm not the only one that bent the factory lug wrench. I immediately went online and bought myself a Cordless Impact wrench and a set of Ingersoll Rand impact socket set. My wife looked at me like I was retarded. She said it's overkill for a bent lug wrench.
while true, the breaker bar is a $10 insurance that you won't damage the torque wrench.
Using a torque wrench for loosening makes no sense.
Get your lug wrench or a ratchet, slide a long pipe over the arm, make sure it's on the bolt tight and you're good to go with 1/10th the effort.
1 Post
2012 E550 Cab
Breaker bar, impact socket and a 24" piece of pipe that fits over the breaker bar. If that doesn't work get a longer piece of pipe. This will either losten the nagging bolt or break it off. Never had one break but with considerable effort you possibly could break one. Take a little care and this will save your back from some sleepless nights. Good luck
Ingersoll Rand makes great quality stuff.
