C63 AMG (W204) 2008 - 2015
HELP! AZN OPTICS Eyelids Problem
Old 02-24-2012, 11:27 AM
Handled63's Avatar
fast MoFo
Hey Guys,
I have AZN OPtics eyelids installed on 09 c63. After waiting for eurocharged to shipp back my ecu, after putting it in and starting the car, the eyelids dont go on when you"unlock" the car.
- once starting the engine, eyelids work fine, all are one at 100%.
- problem is when i turn the engine off, take the eye out, and lock the doors, the eyelids are suppose to stay on for about 20secs before they turn off. At this time, I have only 1 out of 4 bulbs on, and its at about 10% output.
-someone please help.....any suggestion?
Old 02-24-2012, 11:56 AM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Check you selections under Lighting in the hu Convenience settings?? I think you can control that feature in there somewhere
Old 02-24-2012, 01:27 PM
LandSeaAir's Avatar
2008 W204
Considering it happened right after the ECU tune, I would think this is more of an ECU issue that AZN optics, you should test it by putting in regular bulbs.
Old 02-24-2012, 03:40 PM
Strafe1's Avatar
2021 E63 S Sedan
if you disconnected the battery at any point, you will have lost your settings for the convenience features, among other things. I don't know if this applies to you.
Old 02-24-2012, 03:54 PM
BAD430BENZ's Avatar
360 Modena TT
bingo
this happened to me when i tuned my ecu . just reset everything
Old 02-25-2012, 12:02 AM
Handled63's Avatar
fast MoFo
thank guys, driving home today, i was wondering that, but I didn't disconnect the battery, regardless Ill reset the setting see if that helps, will update.....
Old 02-26-2012, 01:56 PM
Handled63's Avatar
fast MoFo
still no luck! i enabled all the cluster lighting options. the bulbs are working fine once I start the car and im driving, just no output when parked and on delay before it turns off. this is what im missing upon locking the car...
Old 02-26-2012, 05:11 PM
Stevedotmil's Avatar
W204 2010 C300 Sport/6M
It's a lighting setting. You have to have your headlight switch in Auto as well. The fogs should come one at the same time.
Quick Reply: HELP! AZN OPTICS Eyelids Problem
