W204 C-class LED tail lamp retrofit module
2017 G63
I have access to this module which makes the retrofit much painless.
This is for OLD W204 C-Class with NON LED tail to LED tail retrofit.
Left = before module, not light up properly /// Right = with module, zero programming, 100% factory light
Here's what it looks like
PRICE IS NOT SET YET. but it will be between approx $250 USD.
If there's enough interest I can put together a group buy.
Moderator, if needed I can sign up for a vendor account.
2017 G63
There is one for each side. installation involves 7 wires to be cut and spliced, but it's easily reversible. The details of how it works was not disclosed by the company. It retains the factory bulb out warning when something does fail, and there's no delay in the light output.
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
Left = before module / Right = with module, zero programming
PM Sent
2011 W204 C300 mm pano
Will this work with non led tails to retro fit? Sorry been following but got lost in all the threads about if it was only for the people with oem led tails already
2017 G63
Yes. This is for older W204 with NON LED tails to retro fit.
It will be around $200-$250 price range, do you guys think it's reasonable?
if so, i will work out the details and start bringing them in, if there's enough interest.
Thanks now one more question red/yellow light euro version and red/red US version is that right or is there only one? And I'm in if i can get the red/yellow tails for a fair price haven't been looking was waiting for this fix first
2017 G63
Just the parts? or Parts & Labor?
Correct me if I'm wrong - I don't need this module if I already have the LED tails?
I thought this will cancel the rear foglight error.
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Nice idea, but the wire nuts are a no no.. it looks horrible, and they will come loose and cause a short. They were never designed to be used in locations where there is movement.
Change that out to heat shrink connectors, or use a crimp on proper connectors. If you insist on using wire nuts, then atleast use electrical take to hold them to the wires, similar to this image I randomly found on the internet
So is there a product for W204 LED to 2012+ W204 LED?
2017 G63
2017 G63
