Fogs on 09 to match HID's
The Diamond Vision are definitely whiter looking light than the Crystal Vision which has a yellow tinge to it. I have tried both.
Here is a pic of mine with Diamond Vision and Azn eyebrow 5000K LEDs .
Black C63 Kleeman, 1965 Backdraft cobra 427 Roush, 1969 Z28 555ci (pump Gas) Shafiroff
I just ordered another set of the Diamond Visions....Don't know why one side seems brighter...maybe a F'd up bulb.
http://stores.ebay.com/prolight/_i.h..._sid=306906571
Haha... It might be the bulb or it might be a bad ground or poor connection to the bulb. I would check the connection first by removing the connector and check it and the prongs on the bulb for corrosion. Clean them with electric contact cleaner or fine abrasive (if dirty with corrosion, oil, etc) and reinstall. If that does not work check the power side of the connector with a voltmeter to be sure you are getting 12V. If that seems fine trace the ground wire back to is chassis ground, remove, clean and reinstall. Has to be one of those things. I suppose the first thing to try is to swap the bulbs side to side and see what happens. That will tell you if it is a bad bulb or connection problem.
2010 C63 AMG
I switched out my main HIDs to 6,000K and went from there. I matched the eyebrows with 6,000K LEDs and the fogs and high beams with Philips Diamond Vision. I have tried many other combinations. This is the best match I can find.
