C63 AMG (W204) 2008 - 2015
Brake is squeaking
Old 03-08-2012, 06:01 AM
vessproms's Avatar
C63
Brake is squeaking
Every time i slam on the brake , it squeaks like brake pads are done. But dealer checked and still got 50-60% so what's happening?
Old 03-08-2012, 08:22 AM
melmanc55's Avatar
C63 AMG
Had the same problem. It was suggested to me to use this. I did and it's awesome. It's the dust created by your brake pads. Clean your wheels with this and at the same time spray this over your calipers and brake pads. Rinse and no more squeak. Eventually the squeak will come back but it takes a while. This is the best option.
Oh follow directions on bottle. Wet wheels first then spray. Wait 15-20 sec then spray off. Make sure you get the cleaner that is safe for all wheels.
Old 03-08-2012, 09:53 AM
Former Vendor of MBWorld
Staff@RPM's Avatar
Heres a link to a thread with what you need.
https://mbworld.org/forums/c63-amg-w...ake-noise.html
Old 03-08-2012, 04:49 PM
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Question
Try this.
Find a quiet road, & do 10 quick hard stops from 60MPH to about 5MPH....in quick succession.....Do not stop.
That will get your brakes quite hot, & should get rid of any built up rubbish....which could be causing your squeak.
I would suggest it's worth a try.
Cheers, Pickles.
Quick Reply: Brake is squeaking
