C63 AMG (W204) 2008 - 2015
Tilt steering adjustment lever
Old 03-14-2012, 12:49 PM
benzvr6's Avatar
01XC70Wet/09C63Dry
Broke my tilt steering lever... don't ask....
Dealer quote... parts and labor to replace the switch/lever 1700$ Ouch!
Ideas anyone...
Old 03-14-2012, 01:22 PM
vessproms's Avatar
C63
are you able to adjust it now? You broke part of it or all of it?
Old 03-14-2012, 02:00 PM
cptdaz's Avatar
home the point
Looks like the lever isn't sold separately but together with the steering column cover. The entire steering column replacement is about $850. Still, $1700 seem excessive.
Old 03-14-2012, 02:46 PM
benzvr6's Avatar
01XC70Wet/09C63Dry
Lever is broken flush... nothing left to adj. Use the memory presets to get adjusted.
Will call the other MB dealer to see if its the same story.
May also bring to local repair shop to see if can be re-attached "creatively"
Still open to your ideas, tks
Old 03-14-2012, 10:55 PM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
OK, for the good of the group, how did you do it?
Old 03-15-2012, 10:33 AM
benzvr6's Avatar
01XC70Wet/09C63Dry
I'm embraced to say that I bought the car with the broken lever... thinking it wouldn't be that expensive to repair/replace. The 65 yr old... nice guy... I bought the car from was at least 6ft4. Had a hard time getting in/out of car... and forget the seats... Said that he was just getting use to holding his breath to squeeze between the bolters. Broke the lever getting in/out of car.
So lesson learned for me in a costly way... hope this helps someone else!
Old 03-15-2012, 01:35 PM
derspi's Avatar
2009 C63
I'd try junkyards and look for any W204 C sedan that may have that lever. For $1700, I'd try to Mcgyver first if it was me.
Quick Reply: Tilt steering adjustment lever
