C63 AMG (W204) 2008 - 2015
Clicking Sound
Old 03-24-2012, 07:18 PM
AMGeer's Avatar
'12 c63 AMG coupe
Clicking Sound
12 c63 p31 with about 1800 miles on it... From cold start heard this odd clicking sound from the engine... Went away after driving for a little while and oil to temp and didn't happen after next start... Any ideas?
Old 03-24-2012, 10:02 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Normal.
Old 03-24-2012, 10:29 PM
Merc63's Avatar
C63 AMG
Lifters. Use 5w40.
Old 03-25-2012, 12:08 AM
Illusive's Avatar
2012 C63 AMG
Like the others have said, just your lifters. Go get a few Liters of 5w40 and top off your oil until it's between the two red marks. My 63 had this ticking sound this morning, added 1L and it went away.
Old 03-26-2012, 03:23 AM
Merc-Skycap's Avatar
AMG & RR
If it continues, record it and post it here for us to hear exactly what kind of noise. Should be a simple fix as stated above.
Old 03-26-2012, 01:34 PM
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
Did your car sit for a couple of days before you started it?
Old 03-26-2012, 02:06 PM
AMGeer's Avatar
'12 c63 AMG coupe
So far the sound hasn't come back... The lifter explanation makes sense ... The car hadn't sat for a while ... Just overnight ... I did run the car pretty hard the night before...
Thanks for all the input ... Very helpful stuff
Old 03-26-2012, 03:58 PM
VaclavSV's Avatar
2012 C63 AMG Black Series
Originally Posted by Merc63
Lifters. Use 5w40.
Why not 0w40?
Old 03-26-2012, 05:45 PM
manuel009's Avatar
G 65 AMG
always happen when the car stay sit for sometime. to me happen every time i start my els. on c63 never happen, but just because i use it as daily driver.
Old 03-26-2012, 06:09 PM
Merc63's Avatar
C63 AMG
Originally Posted by VaclavSV
Why not 0w40?
0W40 hasn't been used in the M156 for years.. Some dealers in the states are still using it for some reason. Its too thin and leaks out of the lifters when they are sitting..
Old 03-26-2012, 06:24 PM
VaclavSV's Avatar
I don't believe this to be true. My dealer is an AMG centre and they told me to use 0w40.
Old 03-26-2012, 07:16 PM
_AMG_'s Avatar
C63
The ticking sound is the lifters, goes away after you start driving for a little bit.
Old 03-26-2012, 09:03 PM
Illusive's Avatar
2012 C63 AMG
My dealer is an AMG centre and they told me to use 5w40.
Old 03-26-2012, 09:43 PM
Rsquad911's Avatar
Why not 0w40?
There was a TSB a long while ago telling all dealers to stop using 0W40 in M156 motors and use only 5W40.
My dealer had no clue till he pulled up the TSB from 3 years back. He said oops I must have missed it.
This is why I do my own oil changes.
Old 03-26-2012, 09:46 PM
gthal's Avatar
2012 C63 coupe
You should have your dealer double check... mine uses 5W40 for our cars.
Old 03-26-2012, 09:54 PM
khmergod's Avatar
I'm not sure what our stock oil was when it was built, but my dealer uses 5W40 for my oil changes.
Old 03-27-2012, 03:29 AM
izzyAMG's Avatar
2019 GLC63, 2020 M2 Comp, 96 Miata M Edition & 19 Forester
I really believe its part of the break-in process. I had mine do the same thing at around the same miles but it never happened again. I'm now at 2400. It would be interesting to find out if yours will come back.
Old 03-27-2012, 02:54 PM
Merc63's Avatar
C63 AMG
Mine too. My good friend is an AMG tech. They haven't used 0w40 for years.
Maybe these guys don't know how to read?
Google hydraulic lifters. You will see why you don't want to use a oil too thin like 0w40. It leaks out of the lifters.
Old 03-27-2012, 09:36 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Can someone post the contents of the TSB please. I have been reading various 0 vs 5 threads for a while now..... It is time to put this argument to bed.. and for that.. we need proof. Someone post the proof (I can no longer access http://www.startekinfo.com/StarTek/)...
Old 03-30-2012, 01:24 AM
balthaser's Avatar
2009 C63 AMG
Can Anyone pull out the TSB number and content about changing from 0w40 to 5w40?
I might need to go do oil change tmr
Old 05-22-2012, 07:05 PM
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
Noted elsewhere I had clicking and rattling now attributed to (ready for this?) washing the grill with a sponge. The grill once came loose. The clips holding the grill are not up to it. The sound was like dry lifters or loose pulley. Only happened twice. There is sometimes the faint sound of lifter noise which quickly subsides.
Old 05-22-2012, 07:34 PM
AMGTTV8's Avatar
AMG
+1
Old 05-22-2012, 08:17 PM
IStern's Avatar
2012 C63
Is this a sound you can hear from inside the cabin? Or do you need to pop the hood?
Haven't heard this since I bought the car. My dealer says mobile 1 5w40.
Old 05-22-2012, 08:20 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Its normal on very low mileage C63. I always use 5-40 mobil 1. Had ticking sound way back. Now with 25k+miles no more ticking sound.
Old 05-22-2012, 10:20 PM
Merc63's Avatar
C63 AMG
My grill is broken off on the passenger side too.
Damn cheap plastic bolts
Quick Reply: Clicking Sound
