C63 AMG (W204) 2008 - 2015
Mid pipes rumbiling noise
Old 04-04-2012, 02:55 PM
clichere1's Avatar
W205 C63S E.1
Hi guys ...
I have 3" mid pipes, and after a while from using it, I hear them rumbling and it seems they are bumping into this piece (red circle)
Although I lift the pipes up a bit and lower the holding bar (with washers and long bolts), but with CA 101 bumps it came down and start making a noisy rumbling.
Should I tighten the bar on the mid pipes , or take off for good?
Is there any shims or material I can use between the bar and the pipes to minimize the noise (and resist heat ofcourse)?
any advice please?
Old 04-04-2012, 03:22 PM
xtyper's Avatar
2013 E63 AMG
Take it off.
Old 04-04-2012, 03:30 PM
dodger63's Avatar
2013 f250 6.7 diesel
Yea mine hit there also take it off or put a spacer in
Old 04-04-2012, 03:53 PM
alrasheed1991's Avatar
2011 C63AMG P31
Take it off
Old 04-04-2012, 06:28 PM
Merc63's Avatar
C63 AMG
Are you guys removing this piece? Doesn't it give the body a bit of support?
Old 04-04-2012, 06:32 PM
bluejae's Avatar
'10 C63
which car is yours?
Old 04-04-2012, 06:36 PM
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
I used spacers on mine... I just assumed this piece was important (Chassis stiffening or something)
Old 04-04-2012, 06:57 PM
_AMG_'s Avatar
C63
Had the same problem with the MBH X pipe, but they supplied me with a modified cross member that clears the mid pipes. Before I put on the MBH cross member I used spacers and it didn't rub any more.
My suggestion would be to use spacers or remove it.
BTW which exhaust are you running on your car?
Kinda looks like the Eisenmann sport.
Old 04-04-2012, 09:14 PM
BerBer63's Avatar
2009 C63
it does nothing for chassis
Old 04-04-2012, 11:44 PM
clichere1's Avatar
W205 C63S E.1
Thank you all for the advice ... I'm taking it off tomorrow.
It's Eisenmann but it's not my car unfortunately
^_^
Old 04-05-2012, 12:23 AM
Merc63's Avatar
C63 AMG
Do you have the magnaflow x pipe on your car?
Old 04-07-2012, 04:48 PM
clichere1's Avatar
W205 C63S E.1
No , not on mine.
Quick Reply: Mid pipes rumbiling noise
