Sign in using an external account
| C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2010 c63 AMG
Can they find out that the car was tuned?
#2 |
Drives: 13' M3 E92
I believe any dealer can do its series of test and find out if your ECU was touch or not. You should not be concern if you are just bringing it in for service but when your car has warranty issues and when they find out, they can deny warranty work. With my prior EVO X I can switch between my stock and mod setup by using the COBB access port but I don't think MB tuners have similar option. They should but i'm not sure.
#3 |
Drives: home the point
There are several of threads on the topic.
ECU Tuning question... ECU Upgrades-Detectable By Dealers? How easy is it to swap ECU's? |
#4 |
Drives: C63 AMG
My tech has not been able to find anything that tells him the car was tuned with his software at work..,
But that doesn't mean it's not possible with further investigation... I remember awhile back a member on here had an engine failure with a tune and exhaust (headers), the dealer didn't find out he was tuned... But they made him buy a new exhaust system and return the car to stock before replacing the engine... |
#5 | |
Quote:
#6 | |
Drives: Steel Grey Metallic C63!!
Quote:
When you have an engine failure, the techs have to submit the claim to headquarters. From there, HQ will have them pull the ME (ECU) for them to evaluate. First thing that they will see is that the ME has been opened. Once that has been decided, there is nothing that MB will do for you. Other than goodwill from the dealership. |
#7 | |
Drives: C63 AMG
Quote:
Well the guy on here got a new engine and he was tuned according to him.. All he had to buy was a new exhaust system($9000) and they replaced his engine....
__________________
Weistec stage 3 w/ built tranny. ---------------------------------------------- PARTING OUT ENTIRE 2009 C63 AMG! http://mbworld.org/forums/c63-amg-w2...-2009-c63.html |
#8 | |
Drives: C63 AMG
Quote:
There was a lot more to the story.. They never did find out what caused it to my knowledge... He ended up deleting the post...
__________________
#9 | |
Quote:
#10 |
Drives: C63
I believe that they got some ways to know either your car is tuned or not
#11 |
Drives: MB Master Tech. 04 S600, 91 240SX 1JZ swap (FOR SALE), 00 ML55, 98 C43-55 Swap With Blower!
As a dealer tech, it is possible to tell its tuned IF you know what to look for. Most techs wont be able to tell or even care if it is tuned unless you have a unusual drive ability concern. It would be a hassle for us to bring it up with management. I would not worry about tuning it. Get it tuned and enjoy it. If you have any serious engine/trans issues, have your tuner return the software to stock before bringing the car in. Most tuners will do this for free
__________________
Only W220 on 20x12's!
#12 |
Drives: C63 AMG
Our ECU's do record certain data points. The MB Star tool is able to see things such as top speed etc.
When I took my car in for a MAF sensor issue the tech asked me how long my car had been tuned for. I obviously tried to play stupid but once he asked "I show your top speed achieved as over 190mph" I had to come clean lol Luckily for me he was cool with it since it had nothing to do with the issue the car was in for.
__________________
#13 | |
Drives: C63 AMG
Quote:
There you have it from the horses mouth. What about keeping your stock ECU and having a secondary tuned ECU? This is what I did... Just threw in the stock one for warranty and service...
__________________
#14 |
Drives: 09 C63 w/PP, 19" HRE, OE Tune
Isn't a second ECU expensive and completed?
#15 | |
Quote:
With the turbo cars if it throws a code under full throttle and its tuned, engine load will be more than 100%. I've seen as much as 140% engine load. It will store data points when the code was stored such as load, speed etc. usually 20-40 different data points. most are of no concern to the tech during diag though
__________________
#16 |
I wouldn't bother personally, Just find a service writer and mb tech that's cool or even a enthusiast and you will nave no issues with warranty. It may sound stupid but try buying them off with snacks when you arrive. Believe it or not it will make a world of a difference. You will be that "one" customer that all wise brings in cookies or something and they will go out of there way to help you
__________________
#17 |
Someone said that wasn't possible without a lot of hassle since the vehicle is "paired" with an ECU.
#18 |
If they are both paired to the same vin it "should" be ok. You cannot use a ecu from another vehicle
__________________
#19 |
And how much effort is it to pair an ECU to a different VIN? Oh NM you're saying you can't. So if you buy a new ECU, you have to give the dealer your VIN and they will pair the "virgin" ECU?
#20 |
Well yes and no, someone on this forum can clear vin's from m.e.'s (motor electronics/ecu) if you do get a used one, however its unusual. pm me if you need his name. but the dealer will need to code it. It does whats known as scn coding. The star computer sends your vehicle data to mb then mb sends back a coding string that is loaded to the m.e. automatically. Then the m.e. is coded to the vehicle. I'm sure the dealer will be curious to as why you want to purchase a additional m.e. for your vehicle though
__________________
#21 |
So like I said, a lot of hassle. Thanks for the info stockc43.
#22 |
Thanks guys for all the replies. I think I'm going to move forward with MHP's v3 tune.
Hopefully there shipping process is quick since this is my daily driver.... |
#23 | |
Drives: AMG C63, Porsche 996TTX50
Quote:
+1. Additionally they can tell if the ECU has been removed from the vehicle without even checking to see if it's been opened. Too bad no one has come up with a flash that works through the OBD2 port yet.
__________________
Current 2003 996TTX50 2009 C63 2009 Lexus RS350 (wifeys car) In Loving memory of my bank account 2006 X3 2005 C55 1999 C43 1997 M3 4Dr 1995 325 4Dr 1985 318i 1995 Porsche 993 RS 1985 Porsche 911 widebody 1983 Porsche 911 Cab 1980 Porsche 911 1978 Porsche 911 |
#24 | |
Quote:
__________________
#25 |
Drives: C63
Doubt it, unless they physically take out your ECU to inspect it.
__________________
| Tags |
| amg, c63, car, dealer, ecu, find, obd2, port, put, returned, sound, stock, thatthecar, tune, tuned |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
