Race Ramps in stock now
Former Vendor of MBWorld
We have been using these around the shop and they have proven to be extremely helpful to us. If it is hard to get a jack under a low car then these ramps will make your life much easier.
PRICE- $97.00/pair
We do stock the entire line of race Ramps so we can help you with any of your needs.
PRICE- $97.00/pair
We also have some good ramps for the DIY'er out there. As you can see you drive your car up these 2 piece ramps and then you can remove the ramp to give yourself more space to get under and work on the car.
These 67 inch Race Ramps XT have a gentle, 10.75 degree angle for your low clearance vehicle -- but don't let that "gentle" stuff fool you. Our solid core design ramps are the toughest around, supporting up to 3,000 pounds and tires up to 12 inches wide. Whether you've got a Corvette or other low clearance vehicle, this low profile car ramp will get the job done. The 67 inch Race Ramps XT are ideal for oil changing, car detailing or other routine maintenance. Expect to be surprised, because you won't believe how easy it is to drive up our ramp.
These lightweight, low profile car ramps easily lift your car 10 inches off the ground, but they weigh only 15 pounds each, meaning that doing maintenance on your low clearance vehicle won't be the usual chore (no more heavy blocks of wood!) Most of all, our 67 inch Race Ramps are safe and Unscootable, hugging the ground and never slipping or sliding no matter what the ground's like -- grass, dirt and yes, even ice!
PRICE-$352.00/pair
PRICE-$352.00/pair
