C63 AMG (W204) 2008 - 2015
Hoosier or Mickey Thompson??
Old 04-09-2012, 11:59 PM
Merc63's Avatar
C63 AMG
Which are better drag tires?..
Mickey Thompson ET street radials or Hooiser DOT drag radials??
They are pretty much identical, except the Hoosier is a 40 tread wear while the MT is a 0... Also the Hoosier is 6lbs lighter per tire.
Please advise guys, thanks.
Old 04-10-2012, 12:13 AM
Even Money's Avatar
'15 VW GTI
I had the 275/40/17 hoosier drag radials, they were light..I think about 21 lbs. I'd go with the lighter tire.
Old 04-10-2012, 12:33 AM
Merc63's Avatar
C63 AMG
http://www.dragzine.com/tech-stories...-drag-radials/
Good article about DOT drag radials. They say the Hoosiers are meant for strictly track use. They are DOT approved but only because that is needed for a particular class in drag racing..
I am going with the Hoosiers.... They are 6lbs lighter which is a pretty big difference too.
Old 04-10-2012, 12:47 AM
Even Money's Avatar
'15 VW GTI
I will say that when I first ran these at Pacific Raceways, they told me that in order to come back, I would have to get wheel studs/nuts. The tech inspector reasoned that these are basically slicks, essentially since there are only two tread lines on the tire, and that as such, I had to have the wheel studs and nuts. Not sure what your track will require, but I would get them anyway just for the added safety factor.
Old 04-10-2012, 07:23 PM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
6 lbs is a big difference in unsprung mass
Old 04-10-2012, 07:54 PM
Merc63's Avatar
C63 AMG
Ya I agree, I went with the Hooisers, which are the lighter ones... I've read they are pretty much a drag slick with a DOT stamp on them and no intended for use on the public roads at all..
Rims are on the way and tires should be soon. Track opens at the end of the month and we will see how they work.
Old 04-10-2012, 10:10 PM
RedBullJnky's Avatar
you to Hate
You made a good choice! I've raced with both and the Hoosier is stickier I think, and lighter. Never had a problem with Hoosier, but the Mickey slipped on me a couple times. Try launching 10ft. and turning side ways. Now I have new Hoosiers on the way.
Old 04-10-2012, 10:17 PM
WaynerMenard's Avatar
bmw
Quick Reply: Hoosier or Mickey Thompson??
