C63 AMG (W204) 2008 - 2015
Convert to facelift hedlights
Old 07-04-2013, 10:19 AM
  #101
Spooler's Avatar
09 C63, 04 E55, 93 500e
Has anyone ever gotten through with the headlight conversion?
Old 07-04-2013, 02:40 PM
  #102
Alwoody's Avatar
C63 AMG Carlsson Tuning
In Germany many many people.
In USA it seems there is no Mercedes Electric Specialist.
Old 07-28-2013, 10:19 AM
  #103
aty
aty's Avatar
2018 GLC 43
Originally Posted by mercu
i got a aaftermarket harness from germany (kabel daviko) got a guy coming to install new sam, will update soon. the cabel come complete with wires for leveling sensors but im not going to bother with that as you need quiet a few! hopefully it works!
Any updates on this?
Thanks!
Old 07-28-2013, 11:32 AM
  #104
4ramin's Avatar
2010 C63,1989 944 Turbo, 2018-GTR, GLC63S
Sorry but I don't understand why anyone in their right mind would want to do this as the newer c63 looks like a regular c class to me with its lack of aggressiveness. The BS now looks great with the wider stance and the aggressive bumper. This however is just opinion.
Old 04-30-2014, 02:28 PM
  #105
toxicwaste's Avatar
C-350 2010 RWD
I have made the FL C63 conversion on my 2010 C350. I've done it because I prefer the look of the new C63 rather than my 2010.
So last spring I had done everything, front to rear except for the headlights and hood. I have just ordered the FL C63 conversion hood and headlights.
My headlights are halogens, so are the new ones I have ordered. They are a C63 replica which is made in Germany.
I need to know if anyone has made the conversion from 2010 to facelift with standard halogen lights. Does anyone know if I will need to tap some resistors to the LED turn signals and LED DRL that are integreted into the headlights? Any help is welcome and here is the link for those headlights I have bought from ebay: http://www.ebay.com/itm/271462248077...84.m1439.l2649 Please note I am NOT trying to turn halogens into bi-xenon. They are both halogens.
And if anyone wants to know why I did not buy a 2013 C63 instead of trying to make my car look like it I will answer you the truth: First of all the 2013 model did not exist back in 2010 when I bought my car. Second, I can't afford the extra $40 grand that I would need to spend to buy one. Final result: I am happy with what I see in my driveway for the extra $8 grand that I have spent so far. I have kept my previous car for 12 years and I expect to keep this one for as long. To each their own!
Old 07-22-2014, 12:51 PM
  #106
jackolee's Avatar
C300
Hey toxicwaste I'm very curious if you installed everything yet and if n it works. I have a 2011 c300 with halogen lights that I want to do this to as well. Thanks for update
Old 07-22-2014, 03:08 PM
  #107
toxicwaste's Avatar
C-350 2010 RWD
Yes, everything is now completed and I have the new facelift front fitted nicely.
Everything works perfectly and the wiring is the most complicated part. I bought the new connectors, I extracted every terminals from the old one and fitted them back into the new connectors with smaller terminals. I used the wiring diagrams for both 2010 and 2013 in order to make sure I was rewiring correctly. I only needed to add a load resistor to one of the eyebrow bulb wire since there are 2 on the old one and only 1 in the new one. No error and everything works fine. It was also tricky to adjust the headlights with the proper alignment at OEM specs since the halogen lens does not beam precisely on one target...
Old 07-22-2014, 06:42 PM
  #108
jackolee's Avatar
C300
Now that I know it's possible I'm going to need your help with mine if you don't mind!!
Old 02-01-2015, 10:57 AM
  #109
Wilsonkpham's Avatar
W212-X204-W204
Hi! I also retrofit the new 2013 Headlight for the old 10' GLK (without replace the SAM-F). Things that works: Lowbeam, turn signal, parking light ...But the Highbeam I can not get it workings. The highbeam shutter using stepper motor with 4 wires ....
Does anyone how I should connect wiring to make it works ? I guess it use CAN to control.
Old 02-01-2015, 10:31 PM
  #110
solekeeper's Avatar
A V8
this seems like wayy too much work.
Old 05-11-2016, 01:40 AM
  #111
C350King's Avatar
2010 Mercedes C350 Sport, 2006 Mercedes C280, 2001 BMW 530i
Disappointing thread, literally no important information here -_-
Quick Reply: Convert to facelift hedlights
