Sign in using an external account
| C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2012 c63 coupe
How to remove 2012 c63 rear badge?
#2 |
Drives: 1M
Hair dryer is your friend.
Apply hot air for a while then it's easy to remove them.
__________________
![]() 2009 SL63 AMG ----------- 2011 1M, 2008 M5, 2007 RS4, 2011 M3 Competition, 2010 C63 AMG, 2006 M Roadster, 2006 SLK55 AMG, 2003 CLK55 AMG |
#3 |
Drives: C63 AMG, BMW 135i
Heat badge and body panel with a hairdryer to help soften the double sided adhesive tape that holds the badge in place.
Use something like dental floss or thin fishing line to slide behind the badge and pull down while gently sawing back and forth to remove the badge. Clean up the residual adhesive on the body with a car friendly cleaner. I use detailer lubricant though many use a citric based cleaner. Clean the back side of the badge as well. Use double side adhesive tape to resecure it to the body. Side note: Mask the area before you remove the badge so you can reposition it back in the correct location .
__________________
![]() MB C63 AMG, BMW 135i, HSV Clubsport R8, Holden SSV Ute. |
#4 |
Does the floss work with the rear Benz logo? I heard that its a bit complicated to remove that one. I heard that u have to remove it from the inside
#5 |
Drives: 2008 M3
rear badge has two tabs, no adhesive.. U need to slowly play with it to get it out... There a chance it can break
#6 |
Drives: C63
The logo has three tabs and be gentle when you pull because it bends easily. U can push it from the inside of the trunk but you have to remove the inside cover of the trunk, same way as if you were changing your license plate bulbs
| Tags |
| 2008, amg, back, badges, benz, c63, cl63, emblem, grill, logo, mercedes, put, rear, removal, removin, replace, spot |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
