How many rwhp should I expect?
It all depends on the tune, headers, etc... probably around 460-470rwhp with 420-430 rwtrq. It depends on the dyno as well.
There are few variables you need to take into consideration.
1 Post
2008 C63 ,2009 SL 63 AMG, 2011 SLS AMG
Yes. If you are making 460-470 rwhp with tune+headers+intake & filters. You should hit 500rwhp and a little over that with a dedicated race tune in conjunction with race gas and some race ported heads. You should be around 500-515 rwhp.
Stick with the 470 whp and shed some weight off the car would be a better idea. Light weight wheels, rotors, Carbon Fiber Hood/Truck. Racing seats. Remove the spare.
The 4100lbs is the problem with the C63. Its a big fat pig.
Dyno = tuning tool.
A dyno number on it's own means nothing, you are suppose to compare that number to a baseline (stock whp) to see the effects of your mods on gains/losses.
For example my stock car put down 308whp on a mustang dyno, 357whp with ecu tune = 49whp gain.
The same car on a dynojet will put down 380whp stock.
In the end a dyno is just a measuring tool for improvements/gains, it's not a benchmark unless you are into e-peen measuring.
