C63 AMG (W204) 2008 - 2015
ANNOYED!!!! eyelids by AZN-Optics Problem...HELP!!!
Old 04-18-2012, 11:19 AM
Handled63's Avatar
fast MoFo
this is really getting annoying!!!
my eyelids bulbs by AZN optics seems to be not working, fitting well. 2/4 of the bulbs( one on left side, other on right) keep giving me the error code due to it not lighting most of the time. BUT, it is not the bulbs because at times, by itself it turns back on, then turns off, then turns on. etc
i think the fitting its not secure enough causing the bulb to move around, and it has shorted twice already burning it.
please help, any suggestions?
Old 04-18-2012, 11:57 AM
Invain15's Avatar
4matic C300
Did you reach out to Mike and ask him what to do?
Old 04-18-2012, 12:40 PM
SPONSOR/MBworld Guru
AZN Optics's Avatar
If it's not gripping tight then is sounds like the metal connector was over flexed and not giving good solid connection. Obviously if the clip loses contact with the voltage plate, it shuts off till it touches again through engine vibration or what not. So it works fine with engine off and not moving? You can try (with power off) take a pair of tweezers and try tightening it down. Also make sure the connectors are free of debris and corrosion which could interfere with the current.
Old 07-08-2012, 12:20 AM
vpt85's Avatar
C300 4matic
This is also happening to me. The LED flickers when the car is off but than turns on once the engine is on.
Old 07-08-2012, 02:13 AM
RuckinAMG's Avatar
C63
One of the bulbs in my eyebrow stopped working and AZN sent me a pair free of charge. No complaints here. Quick to respond to my email. Hopefully you'll have the same experience.
Old 07-08-2012, 09:06 AM
Mort's Avatar
I installed my LEDs a long time ago but I remember having a problem with one, maybe two not lighting properly. I think you can push them too far into the socket and the connection is lost. Maybe try pulling them out just a little and see if you get a good connection. Mine have been working great for 2 years.
Old 07-08-2012, 11:16 AM
Blown63's Avatar
2015 CLS63 S-AMG
This is very common, just use some electrical tape to secure and tighten the bulb into place.
Quick Reply: ANNOYED!!!! eyelids by AZN-Optics Problem...HELP!!!
