Sporadic nav screen pop up at startup
I always drive around with my nav screen down and only pull it up when needed. Lately though, it's been oddly popping up on it's own at startup. Not all the time, just sporadically. Maybe 1 out of every 10 starts.
Anybody else experience this or have an idea what the cause is? It's really annoying.
2 possibilities:
- will depend on whether you had audio on when you last turned off the car. Lets say you put the radio on then shut the screen away using the right button. The radio is still playing when you turn the ignition off. Next time you start the car the radio will come on AND the screen will come up
- do you have the reversing camera option? Could it be that you reversed to park for example. I believe the screen will come up and the camera will display when you engage reverse. You park up and turn the ignition off while the screen is still extended. Next time you start the car it will revert to the last setting ie screen up.
