Sign in using an external account
| C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
TPMS questions
__________________
2013 F10 M5 For sale - OEM C63 diffuser, two sets of AMG centercaps, OEM Chrome AMG plate frame- F10 M5 on the way Gone but not forgotten... 1998 Nissan Maxima SE 2000 E46 330ci 2002 E46 SMGII M3 2007 Range Rover Sport S/C 2009 C63 Last edited by PatSC23; 05-03-2012 at 09:46 AM. |
#2 |
Drives: Steel Grey Metallic C63!!
Your TPMS is set at to trigger if it falls below a certain threshold. If your new modulares are inflated at a higher or lower pressure, driving around in them will do nothing to reset the system. You have to reset the TPMS for the specific pressure amount you have on your modulares and then drive around in them. The low pressure warning should disappear right after that.
#3 | |
Quote:
__________________
2013 F10 M5 For sale - OEM C63 diffuser, two sets of AMG centercaps, OEM Chrome AMG plate frame- F10 M5 on the way Gone but not forgotten... 1998 Nissan Maxima SE 2000 E46 330ci 2002 E46 SMGII M3 2007 Range Rover Sport S/C 2009 C63 |
#4 |
So its not resetting at all. Does that mean one of my sensors are bad? Who created a system where you need to take each TPMS sensor off the tire to see if it's broken?
__________________
#5 |
Drives: C63AMG, NIssan NX2000, Pontiac Fiero GT
JEff's experience is also mine. The original sensors are still on the Hankook summers and unamed sensors on the Michelin Alpines. I run both sets at 39/47. In winter wife sometimes reports warning whereupon I find one tire (usually front)
down about 1 pound. Adding 1 pound usually resolves warning light. This spring, for instance, I was able to put the Hankooks back on set at above pressures . Wife mentioned warning light leaving first day, but resolved on way back without reset. |
#6 |
Turns out my TPMS sensor was cracked. It finally broke off and I could hear it in the wheel, but didnt drive on it. The tire also went flat bc the sensor would no longer hold in air at the valve. Had all four replaced and Im good to go now.
On a side note - Reminder guys - DO NOT use metal caps on the TPMS valve stems!
__________________
2013 F10 M5 For sale - OEM C63 diffuser, two sets of AMG centercaps, OEM Chrome AMG plate frame- F10 M5 on the way Gone but not forgotten... 1998 Nissan Maxima SE 2000 E46 330ci 2002 E46 SMGII M3 2007 Range Rover Sport S/C 2009 C63 Last edited by PatSC23; 05-11-2012 at 02:17 PM. |
| Tags |
| 07, 2002, 2011, e46, m3, maxima, nissan, range, replace, reset, rover, sensors, set, sport, tpms, w204 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
