Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C63 AMG (W204)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-05-2012, 03:00 PM   #1
Drives: 2009 C63
Right side eyebrow and taillight flashing
2009 c63 26k miles
I have taken my car in to the dealer now 3 times and they still have not fixed an issue I continue to have.
With the car in the off position headlight position off. The right side eyebrow and taillight flash on and off.
Generally when I switch the position to auto then back off it stops the flashing.
I have searched for this but have not found a solution.
I also have had a starting problem occasionally - turn the key and nothing happens, turn it off and then turn it back on and it will start. I found this awhile ago but can't seem to find a thread on this again.
Thanks for any help.
To remove this ad, register today or login if you already are registered!
bjjtapout is offline   Reply With Quote
Old 05-06-2012, 05:17 PM   #2
Drives: 2009 C63
Bump. Anyone?
Old 05-06-2012, 05:41 PM   #3
Shifter's Avatar
Drives: ///AMG
yes,. you have a faulty Light module, the switch you use to turn on the lights is bad. I have seen and fixed this problem many times!!
Edit--not related to your starting issue, only the lights flickering.
__________________
Custom steering wheel/TB shaft grind/kleemann headers w/ceramic coating/custom downpipe+xpipe/19" 218 AMG wheels/SC pulley/EC V2 tune
______________________________________
Family's MB's:12 E350 4matic, 09 S550 4matic, 04 E55, 13 GLK350, 14 S-class on order
Shifter is offline   Reply With Quote
Old 05-07-2012, 08:59 AM   #4
Drives: 2009 C63
Thank you very much, funny how you can find out an answer on here and the dealer can't figure it out.
Old 05-07-2012, 09:11 AM   #5
Shifter's Avatar
Drives: ///AMG
Ya, it all depends on what dealer you are stuck with. Not all are created equal. I work at a dealer In FL
Old 05-07-2012, 10:43 AM   #6
Drives: 09 C63
I had my light switch replaced for the same reason.. Possibly also an issue with you, check the connectors to the rear tail lights.. mine melted on the passenger side... Known issue, all done under warranty work.
jvanbrecht is offline   Reply With Quote
Old 05-07-2012, 04:56 PM   #7
CoolBDPhenom03's Avatar
Drives: Vivid Racing '09 C63 AMG
For the starting issue, have you had a shop look at that yet? It sounds like it might be something to do with how the key and ignition communicate. Like it is taking extra time or turns for the ignition to recognize your key. Have you tried another key to see if this is the car or the fob?
Just speculating here.
__________________
--DT
My other ride is a Ducati.
"Speed has never killed anyone, suddenly becoming stationary...that's what gets you."
"Sure the M3 has got a top notch weapon in it, but this is a nuke."
- Jeremy Clarkson
YouTube - C63 AMG by Vivid Racing
HRE | Vorsteiner | H&R Coilovers | Agency Power | Powerchip
CoolBDPhenom03 is offline   Reply With Quote
Old 05-07-2012, 06:31 PM   #8
BAD430BENZ's Avatar
Drives: '99 CLK 430....'09 C63 AMG....'10 GLK
are you really going to trust this guy ? haven't you read his screenname....j/k
mine had the same problem and it was the switch
__________________
PUMP GAS MONSTER
BAD430BENZ is offline   Reply With Quote
Tags
2009, amg, benz, c63, e63, eyebrow, flashes, flashing, light, mb, powered, shifter, side, tail, threading, vbulletin, warranty, working
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
