Sign in using an external account
| C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 09 C63 AMG
Something strange happened tonight.
__________________
2011 Audi S4, Sprint Blue Pearl, DSG, ADS, Stasis ECU, Stasis Exhaust, Stasis Touring Suspension, AWE Intake SOLD 09 OB C63, ARKYM, Eurocharged, Forgestar, H&R, K&N, Revozport, SS brake lines FOR SALE: Forgestar F14s, 19x8.5/19x10 custom brushed/gunmetal w/ Vredestein tires and TPMS - see sig picture. Stock C63 exhaust manifolds (headers), stock C63 springs, H&R spacers 10mm front, 8mm rear & extended lug bolts. PM me for details. Last edited by BK63amg; 05-13-2012 at 02:40 AM. |
#2 |
Drives: 2013 Nissan GT-R BE
May be a software or sensor issue, better take it in for a check up.
Sheep
__________________
2013 Nissan GT-R Black Edition Jet Black 2010 C63 AMG Capri Blue (359,205,P02,P31,105,218,293,318,320,471,731 and 889) (Sold) 2005 Mazda RX-8 Winning Blue (Sold) |
#3 |
Drives: 2010 C63 P31;1971 280SE 3.5(Sold);2003 1500 HD Silverado;2008 R320 CDI (sold);2011 GLK350 (wife's)
The yellow icon is a MIL (Malfunction Indicator Light) or Service Engine Icon not an engine oil icon. You have some error codes. You need to have them read to determine if you need service.
The fan that was running is for the Auxiliary Oil Cooler for the engine oil and not the transmission cooler. Your sudden transmission shifts may have overheated the engine oil and or transmission fluid or just confused the electronics. GL |
#4 | |
Drives: 09 C63 AMG
Quote:
He suspects my oil temp sensor is shot...but I should find out soon enough.
__________________
2011 Audi S4, Sprint Blue Pearl, DSG, ADS, Stasis ECU, Stasis Exhaust, Stasis Touring Suspension, AWE Intake SOLD 09 OB C63, ARKYM, Eurocharged, Forgestar, H&R, K&N, Revozport, SS brake lines FOR SALE: Forgestar F14s, 19x8.5/19x10 custom brushed/gunmetal w/ Vredestein tires and TPMS - see sig picture. Stock C63 exhaust manifolds (headers), stock C63 springs, H&R spacers 10mm front, 8mm rear & extended lug bolts. PM me for details. |
#5 |
Drives: 09 C63 AMG
So my mechanic told me that all both cams threw error codes. I'm concerned that this may be related to the M156 class action suit that's been discussed ad nauseum here (my car is an 09)...it could also be faulty sensors but I won't know for sure until it gets to the dealer tomorrow.
Whatever the issue is, I sincerely hope it will be covered under warranty...I will update this thread with more info as I get it.
__________________
#6 |
Drives: 2012 CTS-V
Hey Jason,
Was it the cam sensors?
__________________
2012 CTS V SEDAN Stage 1 Mods: - 2.5 upper pulley with ported snout/throttlebody - Fluidyne HX - Airaid CAI w/green filter - ID850 injectors - 160 thermostat 12.18 @ 118.98 - STOCK 10.87 @ 127.02 - STAGE 1 Stage 1 Track Video |
#7 |
Drives: 09 C63 AMG
I spoke to the tech working on my car and he said that a pulley tensioner and belt had gone bad, snapped and severed a wire connected to the cam sensor. Apparently, this through everthing out of wack but he said he is 100% sure this was the issue.
Fortunately, everything is being fixed and replaced under warranty.
__________________
2011 Audi S4, Sprint Blue Pearl, DSG, ADS, Stasis ECU, Stasis Exhaust, Stasis Touring Suspension, AWE Intake SOLD 09 OB C63, ARKYM, Eurocharged, Forgestar, H&R, K&N, Revozport, SS brake lines FOR SALE: Forgestar F14s, 19x8.5/19x10 custom brushed/gunmetal w/ Vredestein tires and TPMS - see sig picture. Stock C63 exhaust manifolds (headers), stock C63 springs, H&R spacers 10mm front, 8mm rear & extended lug bolts. PM me for details. Last edited by BK63amg; 05-15-2012 at 10:24 AM. |
#8 |
Drives: 2012 CTS-V
Wow that wire was chewed up. Glad it got worked out and under warranty.
__________________
#9 |
Drives: 09 C63 AMG
Me too, I was afraid it might be something more serious that they'd try to tie back to my tune...
__________________
#10 |
Drives: 09 C63 AMG
So I got some bad news from the dealer last night: the wire that was damaged caused multiple shorts in the harness, grounding was bad and apparently did damage to my ECU. They are now saying I must replace my ECU... and because my ECU is flashed, they will not cover the cost of replacement ECU.
Suffice to say I am pretty pissed off because the damage to my ecu was caused by something completely unrelated but just by virtue of having my tune, I'm screwed. I'm pretty sure the tech isn't bullsh*tting me because he is a friend of my friend and mechanic. Now I'm faced with a bill that will most likely exceed $2K for a new ECU plus diagnostics and labor. I was contemplating sending my ECU out to www.ecudoctors.com as they seem pretty thorough and offer a 5 year warranty on their work. Should I attempt to repair my ECU before ordering a new one? Should i order a new one and attempt to repair my old one with the tune file on it? Any suggestions from you guys would be appreciated.
__________________
#11 |
Drives: CL63 AMG
Sorry to hear that but can't you try to contact your tuner, revert your ECU to stock and then take it back for warranty since you know someone that works at the dealership ?
#12 |
Drives: 09 C63 AMG
There is a seal that was cracked when the ecu was opened - as soon as the dealer sees this, the jig is up. Even if I flashed back to stock, it wouldn't matter.
__________________
#13 |
Drives: 2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Sorry to hear about your bad luck BK, that sucks big time. I would give them hell cuz as you said, the ECU got damaged from the belt/wiring... nothing to do with the tune.
__________________
2010 Calcite White C63 ![]() - Vorsteiner CF rear diffuser - BOCA CF backseat covers & CF trunk spoiler - RevoZport CF sideskirts w/ VIP CF rear skirts - JBSPEED CF front lip & CF roof spoiler - Blacked-out roof, reverse light & front grill - AMG door pins & Hakimov CF trim kit - H&R springs (w/17mm rear spring pads) - 19's OEM V Multi-spokes w/ Yokohama tires (H&R spacers --> 10mm r & 12mm f) - 19's HRE P40 in brushed with tinted clear w/ Hankook V12 tires |
#14 |
Drives: Everything Fast
Buy new Ecu and try to fix old one then u have 2 ECU's
Sry to hear about your troubles hope everything works out for u.
__________________
![]() -OETuning (DD & Race). -MHP Headers & exhaust -Carbon air boxes - & CF intak -aFe Pro 5R Filters oiled -18's F18's Forgestars -Evo Rotors F&R -KW v3. -Quaife LSD -Dad's CF Hood -CF Trunk -CF lip & side skirts -Spacaro race seat -rear seat delete. Best ET 10.97. Pos 600DA//Best trap 128.31 Neg 200DA Best 60-130 7.9 pos 600DA (2 Shifts)//Best 0-60 3.1 pos 600DA////Best 0-100 6.9 pos 600DA Last edited by mthis; 05-15-2012 at 10:26 AM. |
#15 |
Drives: 09 C63 AMG
I'm hoping that this is repairable...going to send back to Jerry@Eurocharged so that he can analyze and hopefully help resolve this...my fingers are crossed...
__________________
#16 |
Tough break, man. I hope the alternate solutions work out for you.
__________________
--DT =============== My other ride is a Ducati. "Speed has never killed anyone, suddenly becoming stationary...that's what gets you." "Sure the M3 has got a top notch weapon in it, but this is a nuke." - Jeremy Clarkson ![]() YouTube - C63 AMG by Vivid Racing HRE | Vorsteiner | H&R Coilovers | Agency Power | Velos Designwerks
#17 |
Drives: 02 CLK 55 AMG,09 C63 loaded with P30
What bad luck. I wonder what couldve damaged the drive belt in the first place?
__________________
02 CLK55-13.1@108.6 stock 95 C36 sold 09 C63-12.6@115 stock OE-tuning-only tune stock filters,charcoals intact-11.9@118.5 best trap 119 60-130 in 8.71sec "VERIFIED"-6speedonline.TUNED ONLY .Stock filters,charcoals intact,93oct. Everything else stock.
#18 |
Drives: 09 C63 AMG
Who are you as what info do you have to update my thread?
__________________
#19 |
Drives: CL63 AMG
#20 |
Drives: 2009 C63 AMG
#21 | |
Drives: 2009 C63
Quote:
*Not all of you guys may get this one* |
#22 | |
Drives: 09 C63 AMG
Quote:
__________________
#23 |
#24 |
Drives: 09 C63 AMG
Update*
Jerry@Eurocharged said he got my ECU back up and running. It appears like it was some kind of a software issue - though I haven't had a chance to speak with him to discuss the specifics. (Jerry if you see this, please give me a call/email/PM or chime in here...) He said he reset the module, reflashed the ecu and cleared all error codes thru STAR. I should have my ECU back today...the moment of truth will come when I plug it back in and fire her up. Fingers crossed... **Update My ECU has arrived at my house...anxious to get home and plug it back. Definitely leaving the office early today...
__________________
2011 Audi S4, Sprint Blue Pearl, DSG, ADS, Stasis ECU, Stasis Exhaust, Stasis Touring Suspension, AWE Intake SOLD 09 OB C63, ARKYM, Eurocharged, Forgestar, H&R, K&N, Revozport, SS brake lines FOR SALE: Forgestar F14s, 19x8.5/19x10 custom brushed/gunmetal w/ Vredestein tires and TPMS - see sig picture. Stock C63 exhaust manifolds (headers), stock C63 springs, H&R spacers 10mm front, 8mm rear & extended lug bolts. PM me for details. Last edited by BK63amg; 05-18-2012 at 10:52 AM. |
#25 |
Bonehead service types at your store but good news for you...
| Tags |
| auxiliary, c63, cluster, driving, dying, fan, fault, happened, m156, oil, sensor, strange, temperature, time, whilst, yhe |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
