Sign in using an external account
| C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2010 c63
weird behavior
#2 |
Drives: 2009 C63, 2000 ML 430, 1994 Del Sol Vtec
I wouldn't think it is a problem. Did the engine cut off as well?
Was this the Sunol grade?
#3 |
Drives: 2010 c63
Im actually not to sure, i think it might have gotten cut off because I didnt hear that low rumble my exhaust is usually giving me and everything was pretty quiet, and I couldnt move the steering wheel, and luckily i didnt have any turns ahead of me and was able to pull over to restart the car lol ....and yes, this was sunol grade
![]() Why/how on earth did the car turn off? |
#4 |
Im curious why you shift into neutral? I for one never change gears in motion - or driving modes as the Manual says not to.
__________________
2013 F10 M5 For sale - OEM C63 diffuser, two sets of AMG centercaps, OEM Chrome AMG plate frame- F10 M5 on the way Gone but not forgotten... 1998 Nissan Maxima SE 2000 E46 330ci 2002 E46 SMGII M3 2007 Range Rover Sport S/C 2009 C63 |
#5 |
Drives: 2010 c63
I just do it for fun because its such a steep hill that I can usually just stay in neutral for almost 2 miles without hitting the gas but I guess I wont do it anymore to be safe.
#6 |
I put it into neutral sometimes. I always change driving modes while driving. I can't imagine why it would be a problem. And if it were really a problem they would probably not allow you to do it via software.
#7 |
If the manual says not to, why does the car let you?
__________________
--DT =============== My other ride is a Ducati. "Speed has never killed anyone, suddenly becoming stationary...that's what gets you." "Sure the M3 has got a top notch weapon in it, but this is a nuke." - Jeremy Clarkson ![]() YouTube - C63 AMG by Vivid Racing HRE | Vorsteiner | H&R Coilovers | Agency Power | Velos Designwerks
#8 |
Im not saying that it's detrimental to change driving modes on the fly - but if the manual says not to I just don't. There's millions of things the C63 will allow u to do do that isn't good for it. I just don't use the rationale that if they allow us to do it, its ok for the car. I can remember one time in the beginning i did it and the car was about to shift, and it wasn't pleasant when the car lurched. I must have caught it in between a shift. So I just don't do it anymore to be safe. Besides, I can usually wait to get to a stop b4 i change driving modes.
__________________
2013 F10 M5 For sale - OEM C63 diffuser, two sets of AMG centercaps, OEM Chrome AMG plate frame- F10 M5 on the way Gone but not forgotten... 1998 Nissan Maxima SE 2000 E46 330ci 2002 E46 SMGII M3 2007 Range Rover Sport S/C 2009 C63 Last edited by PatSC23; 05-15-2012 at 02:15 PM. |
#9 |
Drives: W212 E63 M156 non-pano 18" P2 ParkT NightV
Sounds almost like an engine stall but usually the steering wheel is working, although heavier, when that happens. Is the engine is running? Similar thing happen with my other cars and engine can always be restarted even when the car is moving as long as it's in neutral; then shift back into gear. This really sound strange.
By the way, has anyone ever restarted an engine in neutral while the vehicle is moving? |
#10 |
Safety thing i think , any way some thing happen to me i had an ESP ISSUE that its all over MBworld but now fixed was doing 130mph + then the ESP ISSUE came up every thing is working instead of gas paddle i had to stop and turn off car then turn on , i said why dont i put it in neutral and turn off car while car in motion thats 130mph + and turn it on and it works i done 2 times had no problem
lucky i think
__________________
Dad's Carbon Hood Dad's Carbon Trunk Brabus style Grill MHP Blower Tune MHP Long Tube Headers MHP Mids pipe MHP Catback Exhaust MHP 180F Thermostat MHP Carbon Fiber Airboxes with High Flow Filters Weistec Blower HRE R43 Custom Wide body kit Renntech Front Rear strut Brace Vorsteiner Carbon Fiber Rear Diffuser Evosport rotors Wiestec Ice Tank
#11 |
i believe this is called limp mode, but do not quote me on it
__________________
2011 c300 4matic ![]() CHECK IT OUT! v My Build Thread: http://mbworld.org/forums/c-class-w2...011-build.html |
#12 |
strange thing the ecu went into limp mode.. but you shouldn't go into neutral going down a hill.. especially when it is steep.. so as to have control of the car, rather than gravity takes control of it.. good to hear no harm was done..
__________________
![]() 2008 C63AMG P30 + OETuning |
#13 |
Drives: C63 AMG
For what it is worth I have been changing the trans mode with my car in gear for the last 25k miles and have had no issues. That includes the 200+ passes at the dragstrip doing a burnout in "M" and switching to "S1" prior to staging.
#14 |
Drives: 2010 c63
Thanks for all the info guys. I think it might have been some sort of safety feature but im still not sure. Car hasnt had any problems since and i hope it stays that way, appreciate all the feedback from everyone
#15 |
Drives: 2012 C63 coupe
The other issue is that coasting in neutral burns gas (the engine has to use fuel to keep the engine running as it isn't connected to the wheels) but coasting in gear burns no gas at all... coasting down hills in gear is a great way to save fuel if that matters to you. Yes this is counter intuitive but true... coasting in neutral burns gas... coasting in gear and the engine cuts all fuel and the car burns nothing as the wheels are connected to the engine and they keep the engine running without the need for fuel.
__________________
Current: 2012 C63 AMG coupe | Obsidian black | Red/black interior | Performance Package Current: 1996 BMW M3 | Estoril blue | Track car | Heavily modded for the track but still street legal... barely Previous: 2011 M3 coupe | Jerez black | Fox Red interior | Competition Package | M-DCT ![]() |
#16 |
Good point.
#17 |
Drives: MY2010 C63
i'm sure the manual also tells you to drive safe and don't do burn outs, and i'm sure the car lets you
__________________
#18 |
Drives: volvo
__________________
#19 | |
Quote:
__________________
| Tags |
| amg, c63, clk, dct, driving, m3, mode, neutral, problem, put, putting |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
