Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C63 AMG (W204)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-19-2012, 08:31 PM   #1
crazy1469's Avatar
Drives: 2010 C63
pinging under heavy accel
so i have been noticing that when i punch it the initial burst will cause my engine to ping...i am using 94 octane so that should eliminate poor fuel, the car is completely stock there should be no reason for it to ping!!!
To remove this ad, register today or login if you already are registered!
__________________
Fernando
crazy1469 is offline   Reply With Quote
Old 05-19-2012, 11:03 PM   #2
Maverick1975's Avatar
Drives: Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Unfortunately these engines are notorious for pinging. I took my ML63 to dealer and they "played around with timing" and fixed it. I occasionally get pinging in all my AMGs but very intermittent.
__________________
Vath V63RS 07 ML63
HRE M50
Mille Miglia ex
Brembo GT kit
Expression Bodykit
Brabus B63S 09 C63
19" HRE Comp 20
Weistec Stage 2
Cargraphic LTHs
Revozport Vath Kicherer CF
Drexler LSD
Macarbon CF interior
Mille Miglia ex
Dads CF hood
Boca intake
09 SL63
Revozport CF
HRE 597R
Defilipo LTHs
Weistec Stage 2
Prior hood
08 CLK63 BS
HRE Comp90
Weistec Stage 2
DTM wing
Defilipo LTHs
Vorsteiner lip
Custom hood
12 C63 BS
Kleeman SC
Maverick1975 is offline   Reply With Quote
Old 05-19-2012, 11:56 PM   #3
Drives: Merc C63 wagon (hopefully!)
How are you noticing the pinging???
If you can hear hear it audibly over the loud exhaust note, I'd be worried that it must be a heavy knock!!
WagsC63 is offline   Reply With Quote
Old 05-20-2012, 12:36 AM   #4
DuaneC63's Avatar
Drives: AMG C63, Porsche 996TTX50
Very strange since I'm stuck with 91 craptane and am also totally stock, but no pinging at all.
__________________
Current
2003 996TTX50
2009 C63
2009 Lexus RS350 (wifeys car)
In Loving memory of my bank account
2006 X3
2005 C55
1999 C43
1997 M3 4Dr
1995 325 4Dr
1985 318i
1995 Porsche 993 RS
1985 Porsche 911 widebody
1983 Porsche 911 Cab
1980 Porsche 911
1978 Porsche 911
DuaneC63 is offline   Reply With Quote
Old 05-20-2012, 12:39 AM   #5
Drives: C63 sedan
Quote:
Almost certainly fuel/timing related if it is pinging.
Harold1898 is offline   Reply With Quote
Old 05-20-2012, 01:30 AM   #6
Bit worried about Maverick with his pinging.
Oz fuel has high RON, so shouldn't ideally ping compared with lower RON fuels in US?
Old 05-20-2012, 02:08 AM   #7
SonnyakaPig's Avatar
Drives: MB
Quote:
I'm envious. I've had two C63's and both pinged pretty regularly on 91 octane. The inside of the gas door says minimum 93. With higher octane the car runs much better and no pinging. I've heard of other 63's that don't ping on 91 octane so I don't know what the story is with my cars. Anyway, the ECU will protect the motor in quick fashion when it senses knock.
SonnyakaPig is offline   Reply With Quote
Old 05-20-2012, 02:48 AM   #8
Drives: C63 AMG
I have no clue how your engine is pinging off 91 octane... There are knock sensors on the engine that will retard the timing if it senses knock (pinging)... I believe the engine has the ability to protect itself a fair amount.
Realistically, you could put 87oct in these engines and they would just retard the timing to adapt to the fuel.
I believe its something else.
__________________
Weistec stage 3 w/ built tranny.
PARTING OUT ENTIRE 2009 C63 AMG!
http://mbworld.org/forums/c63-amg-w2...-2009-c63.html
Merc63 is offline   Reply With Quote
Old 05-20-2012, 03:17 AM   #9
Drives: MB
When 91 octane is used some cars will ping. As soon as you increase the octane the pinging stops. That's why it's odd that OP's car is doing this on 94 octane.
Old 05-20-2012, 03:46 AM   #10
Drives: C63 AMG
Quote:
I find that hard to believe. Perhaps they have a faulty knock sensor than.
Maybe Weistec can tune in on the M156's ability to retard timing and protect itself.
__________________
Old 05-20-2012, 09:21 AM   #11
crazy1469's Avatar
Drives: 2010 C63
I always use 94 octane..I to take the car in next week and have them take a look at it....there is no way that an engine with 40k using 94octane should ever ping
__________________
Fernando
Old 05-20-2012, 03:44 PM   #12
Drives: 2012 C63 AMG Sedan (Premium & APX) & 09 C300 Sport 4Matic
The fuel, how can you be really be sure what you used is what what advertised at the pump?
Or if the fuel was stale or had some water in it?
Try another source for fuel and check again.
__________________
2012 C63 sedan, APX & Premium, Magnetite two tone Black/Red interior
2009 C300 4Matic Black on Black
Loved my 2007 C6 Corvette Coupe Red on Black SOLD
Pit-Pony is offline   Reply With Quote
Old 05-20-2012, 03:48 PM   #13
b16
Drives: 2009 C63, 2000 ML 430, 1994 Del Sol Vtec
Quote:
There should be a seal/stamp from the state department of weights and measures that certifies the octane rating at the pump.
b16 is offline   Reply With Quote
Old 05-20-2012, 11:42 PM   #14
Drives: 02 CLK 55 AMG,09 C63 loaded with P30
No pinging with my tuned c63. I use 93oct.
__________________
02 CLK55-13.1@108.6 stock
95 C36 sold
09 C63-12.6@115 stock
OE-tuning-only tune stock filters,charcoals intact-11.9@118.5 best trap 119
60-130 in 8.71sec "VERIFIED"-6speedonline.TUNED ONLY .Stock filters,charcoals intact,93oct. Everything else stock.
Jons95c36amg is offline   Reply With Quote
Old 05-21-2012, 09:57 AM   #15
Drives: 2011 C63
Is the noise one to three "pings" immediately after flooring it, and also is it subsequent with the transmission downshifting? I've noticed my car do that (only had it for a month, so I'm still learning the noises, etc), when sometimes I hear a metallic clicking noise, especially in a tunnel or next to high walls, when I mash the gas. In the back of my mind, I've thought it sounds sort of like knock, but I've also written it off as a probable mechanical noise of something else the car is doing. Mainly because I only ever use 93.
I am quite sure I've never heard the noise when manually controlling the gears...only when it's left in auto and has to slam down several gears. Maybe that's a test you could do to get more concrete data, if you haven't already. Have the car in M and floor it at various RPMs in various gears.
ezatnova is offline   Reply With Quote
Old 07-28-2012, 05:17 AM   #16
6.2AMG's Avatar
Drives: 2011 E63, 2008 ML63
PLEAAAAAASE HELP!!!!
HELP!! 11' E63 headers & catless pipes - Pinging
6.2AMG is offline   Reply With Quote
Old 07-28-2012, 10:27 AM   #17
ZephyrAMG's Avatar
Drives: MB C63 AMG Sedan
Lets say it pings and its more of a headache to look into it and all your guesswork wont fix it. Pinging won't do anything unless its valve related or cam related so I am thinking the engine will run fine, you just have to block out the noise...
__________________
ZephyrAMG is online now   Reply With Quote
Old 07-28-2012, 03:06 PM   #18
crazy1469's Avatar
Drives: 2010 C63
Quote:
that is what is happening with me....but it also does it in manual as well
__________________
Fernando
Old 07-28-2012, 03:11 PM   #19
crazy1469's Avatar
Drives: 2010 C63
Quote:
you have it wrong buddy...pinging will do a lot of damage to your engine, normally an engine that is pinging because of timing or fuel issues....if your are not getting enough fuel to the engine you will run too lean meaning your engine will be running at mad temperatures and you will find your self with a massive empty engine bay when it explodes lol...
__________________
Fernando
Old 07-28-2012, 03:38 PM   #20
ZephyrAMG's Avatar
I understand the ramifications of letting a destructive pinging go but I't talking about an owner who has already cancelled out all other reasons, uses 93 and up octane and has NO OTHER reason for the engine to ping. I'm taking about pinging on a car with no other obvious abnormalities. Also the O2 sensor would be lighting up if fuel is too lean. Second you will have over heating first and foremost so coolant and temps would alerting you way ahead of time...
__________________
Old 07-28-2012, 04:40 PM   #21
crazy1469's Avatar
Drives: 2010 C63
[QUOTE=ZephyrAMG;5300484Second you will have over heating first and foremost so coolant and temps would alerting you way ahead of time...[/QUOTE]
coolant temp and internal combustion temp are totally different....your vehicle will be running at normal operating temp and your combustion chamber will be melting
__________________
Fernando
Old 07-29-2012, 01:05 AM   #22
Drives: C63 AMG
I believe it is nearly impossible for a stock car to ping. You have something called a knock sensor which will retard timing, even if you put 87 octane in it, I doubt you could get it to ping.
Dont you think the merc engineers thought that someone might get trapped on the highway or something where 91 oct wasn't available?? I doubt they said, ahhh screw it if they cant find 91, lets just let the engine detonate itself apart.
__________________
Old 07-29-2012, 01:39 AM   #23
crazy1469's Avatar
Drives: 2010 C63
Ohhh you can get a stock car to ping....specially on 87 octane it will sound like fourth of july under your hood.....and yes the knock sensor is the but it only tells the computer to compensate once it detects knock, so in order for it to de tect "knock" pinging it has to ping and then the. Computer will compensate.....but a stock amg engine should never ping unless there is something wrong with it
Old 07-29-2012, 11:34 AM   #24
Drives: C63 AMG
The ECU is adjusting timing 1000s of times a second. I doubt you can hear that quickly.
Old 07-29-2012, 01:59 PM   #25
Drives: MB
Stock cars do ping on 91 octane at times, so your theory doesn't hold up.
You should try 87 octane and see how it works out. Report back.
Tags
91, 996, b16, c300, c63, code, engine, fuel, heavy, load, loud, noise, octane, ping, pinging, pings
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
