LSD Oil Change
LSD Oil Change
please is there any HOW TO for lsd oil change for the c63 amg?
thank you
thank you
I dont have any dealer close to me, i dont mind doing it, just need to knw the procedure?
Tx
Tx
Unscrew the bottom drain plug. Drain oil. Put plug back in. Loosen top fill plug, attach bottle and squeeze in the oil.
Call the dealer and ask what oil to use and how much.
Please could you help me with the link.
I have the castrol oil already as per manual. What I need is the something to use and squeeze in the oil ?
The plastic Castrol container should have a pull out spout. I filled my diff directly from the container. Might have to wiggle it around a bit but you can fill the diff directly from the container.
thanks mort, just saw it now. ur saying i can do it without the hose and funnel.... do i need to remove the tyres?
