Installing springs, DIY.
There is a DIY in the W204 Forum. GL with the install.
https://mbworld.org/forums/c-class-w...g-springs.html
Hello everyone - reviving an old thread here, but I'm thinking about DIY-ing the H&R springs installation. I've been reading up on this as much as I can for several weeks and still unsure. Also, I've seen every possible DIY walkthrough on here and other forums, but noticed none really specific to the W204 C63, and was wondering if anyone can give me some pointers.
1. First, are the spring compressor tools (photo attached) that you can rent at Autozone or Advanced Auto Parts even capable of compressing the OEM springs on the C63? The more I read up on this, the more I'm thinking this may not work. Putting safety risks aside for a second, I've read some posts saying that even the OEM springs on the previous W203 generation were too tight to compress with rental tools. If anything, I'm guessing the C63 OEM springs would be even harder to compress if not more? Can anyone confirm/debunk this?
2. Assuming I can get past the above issue, do I need any special tools to get the upper strut nut? I noticed for the W203, people were using a special tool/socket (photo attached) with two tabs to remove this nut. I wonder if I'd need that for the W204? The other socket I see is one without tabs (photo attached). Also, what size do we need for the W204? I've seen some people say 21mm and some saying 22mm?
I'm still 50/50 as to whether I'll try this DIY or just leave it to a shop. The trustworthy shops around here want a lot of $$$ for this work and are hard for me to get to from where I am and my current work situation. The sub-par shops will do it for cheaper but give me less peace of mind - making me think I might be better off tackling it myself (assuming I get past the above issues).
Definitely appreciate this forum and any advise!
I used that exact spring compressor. It will do the job just be sure to ensure it stays on, I used an air impact to run the bolts down, these are the tools I used also;
T40, E12, E16, and E18
Metric sockets and wrenches were 18mm, and 21mm
Take your time and be careful. Took me about 5 hours to complete all four springs.
No lift just jack and stands.
Hey thanks so much guys for your help
Quartz - thanks for confirming for me that it's possible to DIY the H&R install on a C63..surprisingly, I don't remember ever seeing a C63 owner directly confirming a DIY on this. Did you ever have any second thoughts doing the springs instead of a coilover set after the fact? And, I guess you didn't need a special sockets for the strut nut since you used an impact gun to remove them. But, were you able to reuse the strut nut or did you use a new one?
Jason - thanks for the suggestion. I saw these and wondered if the dual clamp version would be safer since it grabs from both sides of the spring. But, then like Quartz said, I've heard they can slide off so... I'll definitely try the ones you showed instead.
Now I just need some info on the strut nut tools..or just invest in an air gun..
Just did mine a couple weeks ago. Definitely doable, but the DIYs on here kinda suck honestly.The only special tools I needed were the spring compressors (borrowed from Autozone, exactly like the ones you posted) and E-sockets, Harbor Freight has them.
The fronts are pretty straightforward, but the rears I decided to go a different route. Instead of messing with moving the exhaust or cutting/replacing the weird 12pt bolt on the inside end of the rear control arm,, I just unbolted the rear brake calipers to get them out of the way, then unbolted the three bolts on the outside end of the control arm (shock, sway bar, and hub). I found this method easier overall. Obviously support the arm with a jack as the spring is still under tension. Good Luck.
Thanks again guys. And great photo...this was really helpful for me to visualize everything.
DiscoBandit - did you use an air gun or impact wrench to get the strut nut off for the fronts too? If not, did the nut come right off without the need for those special sockets I posted?
If you are going to track it then go Coilovers instead. the only thing I used the impact on was the spring compressor. All the rest came apart easy.
I did not have to remove my exhaust either just removed the inboard bolt and pushed it to the side some then the bolt came right out.
Just take be careful with the spring compressor I could see that going bad if you dont pay attention to the spring while compressing it, but I did not have any issues.
Okay, so I confirmed that strut nut was a 21mm nut. But I just realized that the strut rod (the part the strut nut screws onto) has a torx key? (photo borrowed from a DIY thread below) I initially thought this was an allen key - so I've been looking for 21mm sockets that would allow me to get one of my L-shaped allen wrenches in there to keep the strut from spinning with the strut nut. Now I'm more confused. Is there some easy way to get the this strut nut off without using an impact/air wrench that I'm completely missing here?
something like this could work.
They sell a similar kit to this at lowes/home depot.
Agree taking it off with an impact would be easy, but thought I read somewhere stories of stripping the thread upon reinstall using an impact. Was primarily looking for a way to hand tighten the strut nut when reassembling.
Either way, I wimped out in the end and got the springs installed and an alignment done by a reputable shop here (Anthony at A&L) all for about $380 altogether - couldn't beat the price.
C63 AMG, P30
