Need help replacing a fuse....
2010 E63
Hello Fellas,
After ordering a new set of bulbs I came to an understand that most likely its not the bulb issue. My front passenger parking light is not working, I am unable to find any fuse guides in the trunk or anywhere.
Can someone help me with a diagram for a 2009 C63?
Thank You.
-Felix.
Thank You.
-Felix.
The fuse allocation list is in the trunk with the tire changing tools. Open the trunk and lift the floor cover to reveal the spare tire. In the plastic tub in the centre of the tire there is a section with gloves, tire iron and tow hook. It has a plastic cover with a snap closer. Push the lock and flip it open. You will need to remove the tire iron and tow hook. They are held in with friction snaps. The fuse allocation sheet should be tucked under them. If not there look around because it should be in with the tools and jack somewhere. Kind of hidden.
GL
GL
