Headers...anyone on this planet...
most headers are designed for LHD (left hand drive) cars.... USA, German tuners etc...
I am a little concerned about pulling the trigger on headers for a car located here in Asia (RHD)....
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Yes the problem is fitting it round the steering column. Just not sure what modifying it would entail or whether this would screw up the flow of that bank of headers or what. I just don't know enough about it.
W204 C63 /// E92 M3
My car is RHD and at the end I ended up with iPE headers.
They are not true long tubes, they are more like equal length/mid length headers but for RHD this is probably one of the best and few options available.
I put 200 cell HJS cats right after the collector and than connected to a full Akrapovic Evolution system. Then I went for MHP V3 ECU tune.
I am quite pleased with the end result regarding sound and especially power.
Car just pulls, pulls and pulls...
2011 AMG C63
dleung22, which vendor did you buy the iPE header from?
This is definitely my next power upgrade part I'm lusting for. I also prefer to bolt on the part designed for a RHD vehicle, rather than vague descriptions of "modification required to fit RHD".
Hey, I like things perfect. almost to a fault. But you obviously have limited options so you have to do a cost benefit analysis and see what makes the most sense. Unless you have money to burn (which apparently you do ) then just send the car to Holden
1990 300ce supercharged and intercooled
I would start from scratch rather than modify them. I think it would probably be cheaper and you would have a better product. The left side could be used probably straight away but the right side would probably have to be completely redone. If you do not have anyone to do it for you in your area you can make a model of what you want and send it in to be produced. Look at Stainless Headers Mfg. http://www.stainlessheaders.com/customheaders
W204 C63 /// E92 M3
i bought through iPE directly from their Taiwan home office.
