C63 AMG (W204) 2008 - 2015
Blackstone Oil Analysis after 5100km
Old 07-11-2012, 07:42 PM
Pit-Pony's Avatar
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
MY2012 C63 Performance Package:
During this first 5200km I added 1L of Mobil 5W40 Formula M. I changed the oil at 5100km and send a sample to Blackstone for analysis.
Here are the results.
Anyone else with an AMG 63 engine to compare with?
Comment: We're not sure how much is "too much" but you mightwant to keep an eye on your oil consumption as changes in how much oil you have to add can signalchanges in the engine's overall condition.
At this point, nothing unexpected turned up.
Metals and silicon arehigh, but that's common in brand new engines and you should see improvements with time.
Averages show expected metal readings following the break-in period after about 8,800 km on the oil.
The viscosity measured in the 10W/40 range. The TBN read 2.9.
Old 07-11-2012, 08:07 PM
EkS
EkS's Avatar
C63
Here is mine as reference. The latest one was just taken a little over a month ago.
Old 07-12-2012, 01:09 AM
Merc63's Avatar
C63 AMG
You need more KM to get a better understanding of whats going on in the engine.
You metals are high, but this is probably your first oil change and that is to be expected.
TBN is good. I think it starts off at 6 for M1
Old 07-12-2012, 02:54 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
So I did my engine at 8x,000mi at a 7500mile interval
nickel was 5, which was a surprise. Turns out the tappets are 9310 steel with 3->3.5% nickel. You guys have a value of 1.
Now I started to worry about the lawsuit and abnormal wear, but they are also 93% iron. And I had no abnormal wear of iron. Anyone have any other idea where it might be coming from?
Everything else looked excellent.
I will try and post when I can find the pdf.
Old 07-12-2012, 03:40 PM
bhamg's Avatar
C63 AMG
No idea, you would think Fe levels would be out of whack also with Ni at 5. If it were my engine though, I would repeat the UOA (same oil type, same mileage) to see if the trend to high Ni is confirmed.
Old 07-12-2012, 04:11 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I don't understand any of this!
Old 07-12-2012, 07:50 PM
Mort's Avatar
Here is another one for comparison. Don't know how to turn this into a picture to post sorry. Tried scanning but it came out poop.
File Type: pdf
Old 07-13-2012, 12:45 AM
Merc63's Avatar
C63 AMG
Im going to test mine again right away,
My Base number was 1.9 last time.
MB goes wayyyyyyyyy too long with oil changes IMO.
Old 07-13-2012, 02:02 AM
bhamg's Avatar
C63 AMG
It was pointed out to me that my wording was somewhat confusing...what I am suggesting is to run the same brand and type of oil and filter for the same mileage on the new oil change, prior to the next UOA.
Old 07-13-2012, 11:33 AM
here it is, guess the nickel was 6. I have another sample just waiting for me to ship it. Similar mileage.
Old 07-13-2012, 02:08 PM
Seriously, what is the meaning of all this? Measuring the residual elements that make up the oil output to see what?
Old 07-13-2012, 03:04 PM
bhamg's Avatar
C63 AMG
This, from Blackstone:
Oil analysis is a quick, nondestructive way to gauge the health of an engine by looking at what's in the oil.
What does a standard analysis include?
In our standard oil analysis, we perform four tests:
Spectral exam:
In the spectral exam, we take a portion of your oil sample and run it through a machine called a spectrometer. The spectrometer analyzes the oil and tells us the levels of the various metals and additives that are present in the oil. This gives us a gauge of how much your engine is wearing. To learn more about the elements we look at and where they come from in your oil, go to our Report Explanation page.
Insolubles test:
The insolubles test measures the amount of abrasive solids that are present in the oil. The solids are formed by oil oxidation (when the oil breaks down due to the presence of oxygen, accelerated by heat) and blow-by past the rings. This test tells you how good a job the oil filter is doing, and to what extent the oil has oxidized.
Viscosity test:
The viscosity measures the grade, or thickness, of the oil. Whether it's supposed to be a 5W/30, 15W/40, or some other grade, we will know (within a range) what the viscosity should be. If your viscosity falls outside that range, there's probably a reason: the oil could have been overheated or contaminated with fuel, moisture, or coolant.
Flash Point test:
The Flash Point test measures the temperature at which vapors from the oil ignite. For any specific grade of oil, we know what temperature the oil should flash at. If it flashes at or above that level, the oil is not contaminated. If the oil flashes off lower than it should, then it's probably been contaminated with something. Fuel is the most common contaminant in oil.
Old 07-13-2012, 04:58 PM
Cool, thanks for the info. What's the process to get this done and what is the cost? Thx.
Old 07-13-2012, 05:52 PM
bhamg's Avatar
C63 AMG
Follow the link below to have Blackstone send you some free test kit mailers. The basic test is $25. They'll provide you with containers ready to be dropped off at the post office that utilize USPS-approved procedures and containers for a sample of motor oil. I don't ship via USPS anymore though, because it's common for someone at USPS to decide the sample is hazardous (even though it isn't) and not send it through. You will then be out the sample as well as postage. My last USPS-shipped sample took over three months to get to Blackstone so I now use UPS instead.
http://www.blackstone-labs.com/free-test-kits.php
Old 07-13-2012, 06:45 PM
Sweet, thanks!
Old 07-13-2012, 08:33 PM
Pit-Pony's Avatar
Use the post office but just enclose the container in a small box and they won't know.
Old 07-13-2012, 09:18 PM
_timothy's Avatar
c63
did you use the Formula M ESP?
Old 07-13-2012, 10:20 PM
bhamg's Avatar
C63 AMG
Not sure who you are asking but I use the ESP and always have. To the best of my knowledge I'm the only one here who weighs in on oil-related matters that still uses the ESP. I have two interesting ESP samples going in to Blackstone. One is a 3,450 mile (short) OCI that was very high RPM operation for many of those miles (the only period that the car has seen extended redline operation). The other is a 9,120 mile (longest by far) OCI that was almost all highway mileage, for hours at a time.
Old 07-14-2012, 12:26 AM
forcefed6.4ford's Avatar
Location: On a oil lease cracking rock to recover glorious sour oil
Modded 2010 Harley Edition F-450 and a '13 S5
I get mine done at my local Cat dealer. cheaper then Blackstone and no shipping.
Quick Reply: Blackstone Oil Analysis after 5100km
