C63 AMG (W204) 2008 - 2015
Can I run 245's up front on H&R Springs?
Old 08-04-2012, 12:43 PM
ChrisD63's Avatar
2009 040 Black C63, 2009 Arctic White G55, 2012 Storm Red CLS550 4Matic
Will I rub with that setup? Also what size is ideal 245/30/18 or 245/35/18?
Michelin PSS is the tire if that helps.
Thanks in advance
Old 08-04-2012, 03:02 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
U should be fine.. I'm running 245/35/19 on my 19x8.5 +40mm wheels & no rubbing on H&R.
Old 08-04-2012, 04:24 PM
ChrisD63's Avatar
On stock 18's would it be 245/40/18?
Old 08-04-2012, 04:36 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Yeah, the rim size is the last number. The middle number is up to you on how low-profile you want the tire, or what the mfg options are.
Old 08-05-2012, 03:28 PM
_AMG_'s Avatar
C63
As long as your offsets are conservative, you will be fine.
Yes, the stock 18's tire aspect ratio is 40.
Old 08-05-2012, 08:29 PM
Chemical7's Avatar
2014 C63 AMG Edition 507
Yes! I am running 245/40 front and 275/35 rear, on stock 18's, and H&R springs.
Quick Reply: Can I run 245's up front on H&R Springs?
