C63 AMG (W204) 2008 - 2015
Tire Size Help
Old 08-09-2012, 04:43 PM
MNL ICE's Avatar
08 C63 AMG
Tire Size Help
I need your help guys.....just wanna ask if a 275/30/19s will fit my C63 without rubbing? I have a HRE C19s 9.5 at the rear and dropped on KW V3 on the lowest setting and planning to install a Falken 452s. Thanks.
Old 08-09-2012, 04:49 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
275/30/19's will not rub if the wheels are made to C63 offsets.
Old 08-09-2012, 04:58 PM
MNL ICE's Avatar
08 C63 AMG
yes they are...im just scared coz right now i have a 265 and there's a half inch gap between the tires (side) and fender
olszowa12's Avatar
'08 C63 Estate
Falken are very narrow tires so you should have no problem fitting them.
I've run 275/30/19 on +10mm spacers and H&R springs -20mm and had no rubbing issues.
Haven't you sold the car yet?
You were parting it out if I recall correctly?
Old 08-09-2012, 05:00 PM
MNL ICE's Avatar
08 C63 AMG
thanks...and NO im not selling the car just parting out the parts but parting out is on hold
or cancelled ...lol
Old 08-09-2012, 05:04 PM
olszowa12's Avatar
'08 C63 Estate
or cancelled ...lol
That's much better
Are You planning any new mods?
Old 08-09-2012, 05:19 PM
I am Jeff's Avatar
The difference between a 275 and a 265 tire is less than half an inch. The half inch increase is then distributed to the inner wheel well and the gap between the fenders. So it should only reduce your gap by a quarter inch.
Old 08-09-2012, 05:21 PM
olszowa12's Avatar
'08 C63 Estate
It depends on the tire brand as well.
E.g. Falken, Toyo and Dunlop are narrower than others.
Old 08-09-2012, 05:25 PM
_AMG_'s Avatar
C63
Hey Arius, long time no see. How you been?
I remember seeing your setup at the March madness meet and you had substantial amount of room to run a wider tire setup. You should be fine with 275's.
Would you happen to have your rear offsets by any chance?
Old 08-09-2012, 05:42 PM
MNL ICE's Avatar
08 C63 AMG
That's much better
No more.....but im modding my Prius at least its gonna look fast...... I have 2 extreme cars....Fast and Slow!!! I call them "Fast and Prius"
thanks so much
wassup.... I dont know my offsets
Old 08-09-2012, 06:01 PM
Thrilla's Avatar
2014 C63 AMG 507 sedan
It's probably +50, similar to other HRE 19 x 9.5 wheels.
Quick Reply: Tire Size Help
