C63 AMG (W204) 2008 - 2015
Need some advice!
Old 08-13-2012, 06:19 AM
timsamg63's Avatar
C63 C
Question Need some advice!
Hello everyone,
I really need some advice. I am now looking for something to lower my car and make the car rides and feels stiffer. After doing some research, I come up with either the H&R sport springs or the H&R coilovers. Since I am not seeing the track in the near future, I am not really into the pricey kw's yet.
For the street performance, do you guys think the H&R springs are enough for the c63 or it's better to have a set of coilovers?
I also heard someone said, if I am just switching the stock springs to the H&R spring will harm the stock shocks. Is this a bad thing or a good thing?
Thank you so much!
Tim
Old 08-13-2012, 09:15 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
You will be fine with H&R spring on stock shocks. It's a mild drop. I've been running this set-up for almost 2 years now, no problem.
If you want to go lower or be able to adjust, go coilovers... it's a matter of preference.
Old 08-13-2012, 09:21 AM
jobee's Avatar
C63
i agree with Roswell, springs should be fine
Old 08-13-2012, 10:13 AM
timsamg63's Avatar
C63 C
Thank you so much! Will the performance has a big big different between them? Or the spring works as close as the coilovers?
Old 08-13-2012, 10:35 AM
Mikegpr03's Avatar
C63
HR springs are made to work with the stock set up. However for an optimum set up the cool overs would be the best way to go.
Old 08-13-2012, 11:00 AM
timsamg63's Avatar
C63 C
^ thanks for the input
Old 08-13-2012, 02:36 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Springs are good. Coilovers might be a little overkill for what you want to accomplish look and ride wise.
Old 08-13-2012, 03:10 PM
Paculdo's Avatar
06 CTT-S
i'm thinking of the h&r spring setup for a not so agressive drop - and not too expensive too :-) - and the p30 setup is too stiff! but i'm ok with it, my kids complains it's too 'bumpy' though...
Old 08-13-2012, 09:05 PM
timsamg63's Avatar
C63 C
^^ Thanks Will the spring cause the ride become less comfortable?
Do I also need to put spacers? Will they improve the handling a bit or just the look.
Quick Reply: Need some advice!
