C63 AMG (W204) 2008 - 2015
Removing rear seats
Old 09-08-2012, 08:14 PM
ChrisD63's Avatar
2009 040 Black C63, 2009 Arctic White G55, 2012 Storm Red CLS550 4Matic
Removing rear seats
While I was looking through some threads I noticed that some of you took out your rear seats before heading to the track. I know how to fold the seats down but I just can't figure out how to completely remove them. Any help would be greatly appreciated.
Old 09-08-2012, 10:41 PM
BerBer63's Avatar
2009 C63
unscrew the seat belt holders... i think that's it
Old 09-08-2012, 11:17 PM
andrew c230k's Avatar
W204 C63 R171
Pull up on the front edge, then push it back towards the rear of the car. That will remove the bottom seat cushion in the rear, then it will expose screws to remove the side bolsters. The fold down seats are tricky but everything will be exposed once the bottom and sides are removed.
Old 09-09-2012, 12:15 AM
Merc63's Avatar
C63 AMG
The pad you sit on just comes right off.
The rear back seat is what is heavy, about 65lbs Id say.
Its bolted to the car under a 2inch strip of leather that runs along the bottom and top pieces. I think there is about 8 or so bolts that have to be removed. One of them in the middle seat belt.
Its pretty straight forward. You will get lots of road noise and exhaust noise. Especially if you remove all the crap in the trunk too.
Easy to remove the passanger seat too! Its only 4 bolts and its comes right out after you disconnect the electronics on the bottom and remove the seat belt clip. Thats another good 65lbs! Beware u will get a SRS code from removing it and have to take it somewhere to get the code canceled.... I just drove around with the code, but the passenger airbags wont work...
Old 07-13-2015, 02:34 PM
ax3mvrderer's Avatar
2013 Mercedes Benz C63 (W204) Sedan
I've pulled the side panels and seat cushion but I can't get the strip off between the backrest and lower seat. Is it just clipped or are there screws I'm not seeing?
Old 07-13-2015, 02:37 PM
@Merc63
Old 07-13-2015, 08:58 PM
mthis's Avatar
Anything W/4Wheels
@Merc63
just pull on it will pop rite up.
Old 07-14-2015, 12:27 AM
I pulled pretty hard on it. They the split seats and there's a plastic tab with hooks. (Bad description) looks like a MB tool is required to unscrew it. I will post a quick pic when I get to my computer.
Old 07-14-2015, 12:39 AM
mthis's Avatar
Anything W/4Wheels
are you talking about this piece?
Old 07-14-2015, 01:19 AM
Yeah I'll show you the clips I'm talking about 1 min
Old 07-14-2015, 01:23 AM
Old 07-14-2015, 01:25 AM
Old 07-14-2015, 01:27 AM
Appreciate the help and dope whip
Old 07-14-2015, 07:42 AM
mthis's Avatar
Anything W/4Wheels
Thank you
just push down and up and it should pop out. dont forget your seats never been out before so it might not just pop off like mine do that i take on and off every few months .
Old 07-14-2015, 04:39 PM
Thank you
Thanks bro!!
Old 03-04-2016, 10:27 AM
shamrode's Avatar
c63 AMG
You just lift up on the butt cushion? No way! It's really locked down tight!
Old 03-04-2016, 01:54 PM
Jasonoff's Avatar
Received 1,574 Likes on 927 Posts
2010 C63 AMG
Push down and up according to mthis...
Old 03-05-2016, 01:50 PM
mthis's Avatar
Anything W/4Wheels
Bottom seat go to the corner front and yank on it hard should pop rite up. 1st times alway hard
Old 12-10-2019, 07:45 PM
Crya's Avatar
2009 C63 P30
Doing a little dead thread bump here. For those that have pulled out the rear folding backs, how did you access the two bolts on the bracket in the middle of the seat which is behind the seat back and sort of tucked below the black plastic piece part of the trunk? The space is too tight for a socket and not enough room for my hand to get a box/spanner wrench on there. It’s a weird spot to get to even though I can see them clearly. Cheers.
Old 12-10-2019, 08:08 PM
W204 C63 R171
Do you have a picture? It's been years since I did it but I can see if I can dig up the dealer documents how to pull the rear seats.
Old 12-10-2019, 08:44 PM
Crya's Avatar
2009 C63 P30
Yeah that might help. Second pic.
Old 12-10-2019, 09:09 PM
W204 C63 R171
do you have one of these?
Old 12-10-2019, 09:10 PM
W204 C63 R171
This is on a 2009 c63? I'll have a look what they say in the shop manual
Crya (12-10-2019)
Old 12-10-2019, 09:20 PM
W204 C63 R171
This should clear it up looks like you remove the bolt on the hinge.
Quick Reply: Removing rear seats
